CoG is lower for the Cube, simply because the Cube isn't as tall as the D4 - and the displacement of the camera remains closer to its CoG due to the use of a pair of goniometers at right angles. Rigidity - no, they're both superbly engineered and equally rigid. I was saving up for the Cube, but having tried both side-by-side it's a no brainer (for me). The D4 is heading my way. It's lighter, more compact, has the ability to set coarse movements easily by disengaging the gears, and can tilt 90 deg without having to resort to a secondary 'sliding' setting. But, at the end of the day, they are both superb pieces of equipment, pretty much as good as it gets. If I owned a Cube I wouldn't rush to the D4, but if I was in the market for a Cube I would seriously recommend looking at the D4 first. Just my 2c.
I only use ARCA plates with all my gear now .As an aside, recently, when I was a long way from anywhere, I needed to adjust the clamp tension. Arca still doesn't have a retaining system on these things. I was lucky to catch all the bits and get it back together after it ended up in my hand.
Ok. JeffThat's the theory but I can tell you that the reality is that a few days of bouncing around in Iceland loosened it to the point that it needed to be adjusted.
I think one advantage with the Cube design that posters above have missed is the curved rail design, which keeps the mass center of the camera close to stationary. This affects the resonance frequency of the whole system.Robb,
It's only a matter of time before you succumb. You might as well admit defeat now and have Dave send you a Cube --- once you use it, you can never go back. And I was using B1's for years before the Cube, while you were still in diapers!
:ROTFL:
Robb,
:ROTFL:
I travel with the cube quite a bit and have found that an extra plate clamped into the head prevents the adjustment from moving.That's the theory but I can tell you that the reality is that a few days of bouncing around in Iceland loosened it to the point that it needed to be adjusted.
:thumbs:I travel with the cube quite a bit and have found that an extra plate clamped into the head prevents the adjustment from moving.
