Thanks Jack!I like it Shelby!
Actually, there is a technique to do a dark-frame subtraction with the H/39 that my dealer showed me and I promptly forgot because I never needed it ... also, did you try the scene calibration tool in Phocus?thanks
that second image was a puzzler. shot at 100 with the 43mm lens at f8. tried several exposures to get it. the place was quite dark, ended up with a 2 second exposure (counted out). had to bump it in post another stop. this is the H39 hasselblad back which does not do a dark frame subtraction.
in the end i liked the noise effect, but by no means was it under control
i tried 4 seconds, but kept getting a bright stripe flare effect ??? or a lot of banding.
first time i have done relatively long exposure with this back on a tech camera. dp not remember having these problems when shooting in the H body, maybe Phocus does corrections when it sees data from the Hbody, missing with a tech camera
something else i noticed on another shot with a 70mm lnes: I was taking two shots, one at about 12ft focus, one at inf, to use for focus blending. there was about a 1 stop exposure difference, due i suppose to the longer lens extension
This sounds extremely unlikely. To get to 1:1 extension, two stops are generally lost; but that is a much greater extension than going from infinity to 12'.something else i noticed on another shot with a 70mm lnes: I was taking two shots, one at about 12ft focus, one at inf, to use for focus blending. there was about a 1 stop exposure difference, due i suppose to the longer lens extension
No image is visible.Took a few more wit the P30+ .... my theme is fine art figure, a bit of the odd man out here. I like to share them anyway. Maybe my tastes will broaden with age. I got a 30mm Arsat manual focus lens, and some are in the set.
Brynn
Valerie
If you would like to view the whole set, drop me a PM, and I'll be happy to send you the user and password. If you did it once, I'm lazy .... try the ones I sent before.
Dave
My be best to upload images here then to publish those that are not safe for work in the Images to share forum with NSFW in the thread title.double checked post from the Mac, and for some reason images from dropbox are not showing up. Will upload them to my server and link from there ....
Off for a bowl of meundo ... Lucky that my sons are adventurers.
Dave
Very cool shot Yatlee!Here is one taken in Hong Kong during a Typhoon.
Love the colors and texture detail in this one John!bob:,
bit of a squeaky place to get into, i was inside that curved "vessel" that is the door to the dry dock, about behind the third porthole from the right, top row he,he
