glenerrolrd
This is a terrific example of pairing an exceptional lens with the new SL . (you are lucky to have such a nice model !)Sl+50apo
The aesthetic (look) is being produced by the 50 APO ...notice how smooth the image looks and the graceful fall off into the unsharp areas . You see that the image is sharp but it also looks realistic with plenty of detail available . If you captured this same image using for example a zeiss zm 50/2 you would see much stronger edge sharpness and higher overall contrast . Quite different .
I am finding that the SL (and Q) files as they are rendered thru LR ...both have greater saturation and contrast than the M240 files . They have some “Bite” (edge contrast?) similar to the way a Nikon D4s,Df renders . This makes sense for their intended usage .
A professional shooting for web publication is going to love the SL files .
It will be interesting to see how they complete the lens line up . It took a long time to fill in the S lenses but they are as good as it gets from 24 thru 180mm . The SL is going to limp along for quite a while if all they have is the 24-90 . (FYI ...I have the SL primarily because of my desire to use the long R lenses ).
