m_driscoll
Great photos in this thread!
Cheers, Matt
Cheers, Matt
I'm doing it with the built in for LR4. Its decent, just not really great for critical line work. For most images, its fine tho. I sometimes like to use the camera (while traveling) to shoot artwork or line drawings, and that's a pretty critical use.Geoff, I find the lens correction profile in ACR fine. Are you using that or manually adjusting for distortion?
No! I didn't know that. I guess I am slower than you. Thank you for the tip. It will be much more convenient than switching over to shutter priority mode.RX-1 TIP OF THE DAY
This could also because I am slow, but the often published complaint that the shutter speed is fixed at 1/80s in P with Auto ISO is not true. You can set the shutter by simply using the shutter speed dial at the back of the camera. Essentially, in P with AutoISO, you are in a limited shutter priority mode.
But you probably already knew that...
