Please help me identify what equipment I need for a mobile, minimal, portrait setup from background, lighting, remote triggering devices ect....I will be using a M8, M7, and a Sony a900. Thanks!!
I faced a similar situation a few months ago when I had to do a series of matching corporate headshots in three different locations, using a kit small enough to carry on a Learjet 25 (which has
very limited luggage space in the cabin.) What I wound up with:
-- One of those Westcott collapsible backgrounds that springs open and then twists up into a small round package. (Warning: practice stowing it a few times before you try to use it for real! There's a knack to getting it to fold.) I needed this because I couldn't count on uniform, consistent backgrounds in all the locations.
-- Three battery-powered electronic flash units (I used Nikon SB 800 and 600 because that's the kind of camera I have. You can use anything you like.) One of them should have some kind of diffuser, although in a pinch you can just stick a white foam coffee cup over it. You'll also need two slave triggers to fire the off-camera flashes; if you'll be shooting at fairly close distances, you can use inexpensive optical triggers such as Weins rather than radio slaves. The Weins are nice because they're very compact, don't need batteries, and are pretty much unbreakable.
-- A lightweight collapsible lightstand, with an adapter to hold one of the flash units and an umbrella.
-- A small white umbrella to go in the adapter.
-- A big roll of gaffer tape. Optional: a little box (I use a tin that a gift card came in) with bits of colored gels, rubber bands, and some folded-up aluminum foil.
The flash units and other gizmos will fit in a small camera bag; you can carry the stand, umbrella, and folded-up background in a bundle.
How you use this to make portraits: Deploy your background and stand it up against a wall. If it won't stay standing, use some of your gaffer tape.
Put one flash on your camera, pointed straight up, with the diffuser over it. This is your fill light and also triggers the other lights. Doing it this way means you don't need any cords.
Put one flash, with a slave unit, on your lightstand/adapter/umbrella. This becomes your main light.
Put the third flash, with slave, wherever you need it, using a combination of gaffer tape, found objects, and trickery. You might want to bounce it off a ceiling to fill in the background, or tape it to the top of a door behind your subject to create a film-noir rimlight, or whatever. For extra style, use the contents of your little tin box to add a color gel, shape some aluminum foil into a snoot or a gobo, or whatever you want. The rubber bands plus more gaffer tape will form whatever "adapter" you need to attach your accessories to the third flash.
Okay, it's not as minimalist and classical as a north-lit window and a background wall of gently weathered brick. But both those things can be hard to find in office buildings, especially if your photos need to match across locations. The above kit (plus whatever camera stuff you need, of course) was about the smallest way I could think of to solve the problems of consistency, versatility, and portability. Maybe you can think of something smaller or cooler; this is just intended as a starting point for your own inspirations.
