C
carbonmetrictree
I'll be downloading it shortly, any thoughts and/or opinions about the update?
ok, so it may take time for an old dog to pick up new tricks. I haven't checked the OUTPUT files to see if the 4.5 engine is better than the 3.7.7, but so far, quite a few
WHERE IS? questions
Where is;
1.the button to say put processed in a 'develops' folder at the raw location (it is what I mostly used)
2.The highlighting of the icon when the mouse goes over, so you know, what you are going to do?
3.The auto buttons in WB and exposure that take care of shadows, HLTS exposure etc all at once?
A4.n AUTO ofr the color?
5.The batch process method? (why not a 'process all?" i didnt like having to highlite in 3.7.7 to get all images processed
6.The list of processed images?
Also default to 'job name' rather than filename? Maybe others like it, but if you are going to enter a job name the you can select that (or if it sees an entry it should automatically change the selection to 'jab name' Otherwise, often I label images elsewhere and i want C1 to keep
I DO like:
1.the clarity (local contrast enhancement??)
2.The 'process with no sharpening button' (likely use ALL the time with 65+
3. the shadows slider works nicely for lifting dark areas
4.that is loads and exits faster, but does it save the raw changes??
Ah well, I didn't use version 4, and so far I have not seen enough in pro to want to change
UNLESS the image file quality is better. I will be running some tests.....
regards
Victor
