Which Rodenstock centre filter may this be please, Paul?Not necessary with achromatic, LCC is sufficient. You can also get the Rodenstock CF which gets you half way there.
I agree, such a shame! They made these insanely great lenses in very few numbers (43XL, 60XL and 120 Aspheric) and then shut down. I'm glad I got my 60Xl and 120 Asph. in time.The 43 XL is the closest you can get to a single-lens all-in-one architectural solution. It covers so much ground and doesn't need distortion correction which is a godsend in post if you don't own an XT.
Such a shame SK went out of business after 15 million lenses! There are maybe a 200-300 in existence of these and SK produced millions and millions of lenses before that. Crazy to see all of this in this perspective.
Paul, so you can get away with not using CF, just LCC?Yes, it is that one. The gradation is different from the real CF filter so it is not a perfect solution. But it helps a bit with LCC. Given how easy they are to find it is a good second best solution.
By extension, the 28 XL is also amazing for that reason on an achromatic back. You just do a clean LCC exposing for a histogram which is correctly exposed and you can get perfect shots.
Thank you Got them way back in 2014.Congratulations on the 60XL and 120 ASPH.! I'm still looking for those two lenses. Maybe one day.
Yes, if you don’t do extreme shifts!Paul, so you can get away with not using CF, just LCC?
Just one thing to add to Diggles; to be fair, sensor tiling occurs only when you do extreme shifts. I would need to check when exactly it happens in terms of mm on a full-frame MFD sensor, but in practice, it is not that of an issue, at least for me. I'd say 15mm and more without issue if the sensor is in horizontal orientation, but would need to check.Hey Peter,
You'll likely run into sensor tiling with the 43XL and shifts. There is a way to fix it though…
How to Fix Sensor Tiling With Photoshop
My first choice for photo editing is ACR/Photoshop. While looking for a way to apply LCC corrections without using C1/Phocus/Lightroom I ran across this article: https://pduncan.com/2015/11/20/vignetting-4/ The steps outlined in the article do a good job of fixing vignetting, but didn't really...www.getdpi.com
How much movement qualifies as extreme?Yes, if you don’t do extreme shifts!
