etrump
The HR32 is a fantastic lens.wait for a wider version or get the 32mm. Any thoughts?
A question for all of you, I purchased the HR50 couple months ago thinking that is more closer to 35mm in 135 systems which I like a lot. Now, I kind of think that's a bit over kill. I'll probably sell it and wait for a wider version or get the 32mm. Any thoughts?
You also learn that fewer lens choices usually generate more creativity.
It's a tough call and there is no wrong or right answer. After years of shooting and having owned just about every single lens made for every system at one time or another, I can tell you that no matter what you have in your bag, they will always be a little too wide or a little too tight and rarely "just right." Even your zooms! :ROTFL: You learn to make whatever you're shooting with work for the image. You also learn that fewer lens choices usually generate more creativity.
I really want my tech kit to be small and basically in a small shoulder bag. Right now if I stayed with the 35 XL, that darn 60 looks really nice than maybe a 100 or 120. But if I went 4 everything seems to change in my thought process and go 28, 43, 72, 120. Interesting how different it comes down too with that 4th lens.
But I totally agree the less the better and 3 seems pretty darn nice for the tech cam.
I can only speak to the 60XL. On a 60MP Dalsa 20mm of shift is easy and I have gone to 25mm. I use the CF when shifting past 10mm.
The 60XL is sharp to the edge to 18mm of shift and needs a bit more sharpening on extreme shift. However the color cast is very mild and no real issues with detail smearing.
Paul
Is there any data or user knowledge on how the 60XL performs at the VERY limits of its IC? When you refer to 25mm shift on the 60XL is that taking it to the VERY VERY edge on the Dalsa?
