Here we go again.....
1. for the format size they are talking about here, a FF MFDB covers it in a single shot, with AF/Tech lens etc. etc.
2. If I wanted to flat-stitch, the format size with a MFDB back and 120mm IC lens would be 3x this
3. Not sure the MF SLR lenses will be up to the task in the corners with such a small pixel pitch, and if you want to run off and buy the latest Digital tech lenses, then why not go all the way and by a MDFB, you're already in a different price point
4. If you did go with above, not sure infinity focus capability on anything semi-wide will work -- even the mirrorless bodies have the sensor inset by a large margin compared to how a close a DB sits again the rear element on a tech cam.
5. Also assumes that IQ (not just resolution) is apples to apples between something like an IQ160/180 and a Sony NEX
6. Try infinity focus with this thing, especially
7. Then again, Hassey is using the NEX sensor, so perhaps this will be new the setup when the space program resumes, I'm sure some modifications could be easily made for zero gravity and the need to do everything in compressed time
8. I would personally still use a GX680 and D800 for this kind of critical work
9. Not sure why I am spending my time writing this, I should be busy looking for loose change in the sofas to fund my IQ260 Achro back.
