Wayne Fox
I'll admit I've never really not been frustrated with my IQ180. My first one had color cast problems so severe it required an LCC even with the DF/28, 45, and 55 combinations, and also with the Alpa even with the 70mm Rodenstock. they swapped it, but still not great, and one reason I gave up on the technical camera is I really didn't want to shoot an LCC with pretty much every shot. I could get away with it using the 70mm and 120mm rodenstock, although most of the time with the 70 I felt it needed it.
I still frequently get issues that are frustrating, especially when I want to do some major adjustments. It seems now if I have to work over a sky pretty heavily, I"m in trouble, even C1 can't seem to map the 8 sensors correctly. I get all kinds of problems with what appears to be very subtle vertical magenta banding, and the middle seam will almost always show up. If I move into photoshop and work the file some more, it gets worse so I find myself doing things to "fix" it.
Will a recalibration help this? Is it too much to expect to get a perfect density/color match where the sensors are joined? Does anyone else fight some issues even with the DF and color casts?
this is a small crop from a sky output from C1 - this is the middle seam, not over towards an edge. I'm also fighting the magenta blotchiness that you can sort of see in this. A lot of my web jpegs show this in grey skies.
