Steve,
As discussed before the rotating sensor would also be of benefit to Hasselblad V and Tech Cam users.
Would the user base than still be too small?
Joris.
Well, it doesn't hurt to dream, does it?I know, so reasonable Steve, so reasonable. But I want my candy!!!![]()
Very sorry, I'm new comer, what is C1 & CA ?Can't speak to the Zeiss glass - but the 300 pq (assuming its the Schneider) is a fine lens digitally. Its an incredibly sharp lens.
Some of the Zeiss glass may be showing some of its age - but there is no problem with any of the Schneiders. Friend has the AFI 12, and he has no problems with them either. I've seen shots with a good 60-140 zoom with that back and have promised not to look at the results more than once - they are that good and that tempting.
One comment on the Zeiss is that the distortion in them is a bit more complex and harder to clean up in C1, whereas if there is distortion in the Schneiders, its the simpler barrel distortion (the wides, like the 40 and 50) which cleans up very easily. The 50 was recently used for some architectural drawing copy work and was fine with a bit of tweaking in C1, even side sharpness. If heavily backlit, CA can show up.
Okay, I am easily now and planning to go with Hy6.With those lenses you should be absolutely fine!
C1 = Phase One Capture OneVery sorry, I'm new comer, what is C1 & CA ?
You can get it configured so the camera battery is the same as the battery for the back. Convenient.Okay, I am easily now and planning to go with Hy6.
Oh, I see . Thank you very much.C1 = Phase One Capture One
CA = chromatic aberration
This might help: Photography by Graham Mitchell » Test run of Rollei lenses, wide open, on 80 megapixel sensorIt is great to hear that latest DB can be used on Hy6 ,this news make me want to own Hy6.
I still using 6008i and have many lenses, I want to buy Hy6 but I am afraid of my PQ Zeiss lenses may not work well ( resolution , clarity ,etc...) when using in DB.
Any seniors have some experience and can share with me.
I do not know why only the test run photos cannot be view, others are okay.
