Some Lensporn on Sony A7RII -
HCam Master TS with Canon TS-E 17mm
up to 27mm of Shift and 20 Degrees of Tilt.
Stefan
Is there any chance for you to post a link to some shifted RAWS to evaluate images ? I think that would make a purchasing decision much easier
Grischa
Hi Stefan,
So correct me if I'm wrong...but I see Fall+tilt...
Does that mean you add a 360rotational device between the shift and the tilt mechanism? Or is it a fix position as rise/fall+tilt and shift+swing?
Sincerely
David
