Results 1 to 5 of 5
Thread: Firmware Update 1.3 for GX7
    Senior Member hot's Avatar
    May 2009
    Austria
    2,170
    3
    Re: Firmware Update 1.3 for GX7
    I downloaded the update but I can not find how to install it. Any tips?
    Apr 2009
    51
    unzip it, copy to top level of a 32 GB or smaller card,
    stick card in gx7, turn on gx7, see prompt
    or you could follow the instructions at the panasonic joint update service page:
    Joint update service for Four Thirds body and lenses | Download | Digital Camera | Digital AV | Consumer Products | Support | Panasonic Global
    3
    Thanks for the link. I had searched Panasonic for that and not found it. Pressing the 'play' button was the element I was lacking. I loaded the BIN file on a reformatted card and followed instructions but got the 'no picture to display' dialog which is supposed to indicate no update needed but 'Version disp" shows version 1.2. I have no problem with WIFI so the update is not really important to me but I would like to run it anyway. Any suggestions?
    Mar 2013
    Toronto, Canada
    39
    I just did it for my daughter's GX7. You need to format the SD card. Then copy the .bin file onto the top level of the SD card (if you look at the card on a computer file manager, you will see there are a few folders on it. Put the .bin file on the top level. Turn on GX7 and it will recognize the file.
