Page 9 of 10 FirstFirst ... 7 8 9 10 LastLast
Results 401 to 450 of 478
Thread: Having fun with the E-P1
  1. #401
    Terry's Avatar
    New York City
    6,955
    1145
    Re: Having fun with the E-P1
    Yes, when the dealer was showing me the opening they simply turned it and the only time I used the "lever" is to lock it.
  2. #402
    415
    77
    Well, that's good. I thought I had broken mine already! I am going to try the movie thing out today. My daughter is playing Millie in "Thoroughly Modern Millie" and I will see how it does at dress rehearsal. Thanks Terry
  3. #403
    415
    77
    Does anyone have any tips on using the "movie mode". I want to try it today inside a theater. Thanks. -Durr
  4. #404
    terryc
    I am have been having a ton of fun with the E-P1, especially with the Panasonic lenses 45-200 and 7-14. Without testing I find the Panny lenses seem to auto focus a bit faster the the Olympus KIT and the 17mm.
    My own feeling is the AF is a bit of a tempest in a tea pot, it is early days and I am sure Olympus is busy on the next rev of the camera and firmware, etc.
    Using the 17mm Olympus lens with the OVF in mode 3 has some advantages and I have been using this as sort of zone focusing method. Once you get used to it - mode 3 can be very quick.
    From the weekend at the local version of Alice In the Park.
    http://www.flickr.com/photos/streetf...53808506/show/
  5. #405
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    Terry C, Any samples taken with the 17mm that you can point to? TIA.
  6. #406
    Wisconsin
    3,581
    118
    Terry,
    Your Alice in the Park series is excellent!
  7. #407
    Senior Subscriber Member Mike Hatam's Avatar
    Los Gatos, CA
    853
    236
    Terry,
    Can you explain what you mean by "mode 3"? Is this an autofocus mode or something?
    Thanks,
    Mike
    Mike Hatam
    Sony A99, RX1, RX100
  8. #408
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    I got it to work using HexEdit on Mac OS, replacing all the E-30 strings with E-P1 in the ImageCore.dylib file in the Capture One v4.8.1 trial version. There may be a better way, but this one worked for me. No guarantees/warranties, you are on your own, proceed at your own risk.
    Thank you - I used BBEdit - also seems to work fine (and I don't have an E30)
    Just this guy you know
  9. #409
    terryc
    Quote Originally Posted by Mike Hatam View Post
    Terry,
    Thanks,
    Mike
    Greetings Mike,
    Mode 3 ties the AEL-AEF button to autofocus the camera and the shutter button is exclusively for exposure and shooting the picture (very little shutter lag). Once you press the button focus locks and you can shoot away - so most everything in the depth of field zone of the original focus lock will stay in relative focus (depending on F Stop, etc) until you press the AEL-AEF button again.
    Give it try - takes getting used to.
    Best regards. Terry.
  10. #410
    Los Gatos, CA
    853
    236
    Thanks Terry. I have been using the "mode 3" that you are referring too as my standard setup for the past few days. I just wanted to make sure you weren't referring to a different mode 3, as I didn't realize that separating AF from exposure lock would speed up the AF capability.
    It makes sense. I use mode 3, and center point focusing. I pick something to focus on, then point at a highlight and lock exposure, then recompose to shoot.
    The only problem with this method is shooting moving subjects.
    That's why I wish Olympus had 2-3 custom settings on the top dial, where we could store our settings, and the quickly shift to a different setup.
    Mike
    Mike Hatam
  11. #411
    terryc
    Vivek,
    Just a few but will shoot more this weekend and as time permits.
    Best regards, Terry
    http://www.flickr.com/photos/streetf...86144083/show/
  12. #412
    terryc
    Mike
    Certainly agree. The other thing I have done is made sure that release priority is on. So even if the E-P1 hasn't quite figured out the AF I can get a shot or two - most of the time (famous last words) the images are OK.
    Best regards, Terry.
  13. #413
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    Sadly I've been working hard and hadn't have the chance to the take the E-P1 for a real test drive (if the weather is right I'll be taking it into a small trip this weekend). For now here are just a couple of experimental self portraits and a shot of my wife:
  14. #414
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    Quote Originally Posted by terryc View Post
    Vivek,
    Best regards, Terry
    Thanks a bunch, Terry! They look good. My sample (17/2.8) is on its way now.
    BTW, that 45-200 shots at 200mm (from your earlier set) are fabulous!
  15. #415
    Senior Member Brian Mosley's Avatar
    Jan 2008
    2,394
    17
    [QUOTE=Rawfa;117266]Sadly I've been working hard and hadn't have the chance to the take the E-P1 for a real test drive (if the weather is right I'll be taking it into a small trip this weekend). For now here are just a couple of experimental self portraits and a shot of my wife:
    This one is terrific Rafael! well done, and thanks for sharing.
    Kind Regards
    Brian
  16. #416
    terryc
    Vivek,
    Thank you. Question for you - in another post you mentioned the importance of the M adapter being used relative to image quality, such CA, etc. Can you elaborate, I have the Novoflex adapter which they replaced - the new(er) version allows a lens change without taking the adapter off the camera and corrects a (there words) machining error. At the time of purchase (late October early November) it was the only adapter available locally. It seems to work but I have not done any minute testing, etc.
    TIA, Best regards, Terry.
  17. #417
    Jan 2009
    USA
    1,763
    45
    Smile Re: Having fun with the E-P1
    [QUOTE=TEBnewyork;117078]A couple from yesterday working with Monochrome red filter and highlight spot metering. All with the 17mm pancake.
    The conservatory in Golden Gate Park. The colors were so lush it felt criminal to make the pictures in B&W but this is going to be one of my first outings with a converted IR camera
    Hello TEBnewyork,
    Simply gorgeous! I enjoyed visiting the Conservatory in Golden Gate Park when I lived in the Bay Area as a university student. All the best, Leica 77
  18. #418
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    Hi Terry, I think the Novoflex adapter also should have proper paint but the Cameraquest/RayQual has an edge over the others in that they have a little plastic ring in the rear (to protect the lens contact pins in the camera). This also acts as an additional (stray) light proofing element. Quite an ingenious design. The reason why I keep claiming this is the best M adapter there is.
  19. #419
    terryc
    Thanks Vivek! I just might have to order a RayQual.
  20. #420
    Ithaca, NY
    3,538
    A few snaps with the E-P1 and kit lens from an evening walk through the Cornell arboretum.
  21. #421
    1,860
    All nice Carl. Since I love monos, particularly drawn to the 1st--nice tones, detail.
  22. #422
    Ithaca, NY
    3,538
    Quote Originally Posted by Diane B View Post
    Thanks Diane. I don't know the name of that particular plant, but the strong texture of the leaves makes it a good subject for monochrome rendition. I used SEP for B&W conversion and a custom split tone curve that yields warm mid tones and neutral highlights.
  23. #423
    804
    Some fun with the pop art filter.
  24. #424
    Wisconsin
    3,581
    118
    Quote Originally Posted by retow View Post
    Retow, Perfect subject matter for the pop art filter! Nice series. I enjoyed them all.
  25. #425
    1,860
    Quote Originally Posted by scho View Post
    That's interesting. I have those same curves saved and have used (but not recently)--as well as Ken Lee's (and his duotones). I'll have to go back and revisit.
  26. #426
    804
    Ok, I had enough pop art for today
  27. #427
    Jan 2008
    2,394
    17
    Hi Terry, just caught up with your Alice in the Park set - superb work. Are these out of cam jpegs? if not, which raw converter did you use?
    Well Done, and thanks for sharing
    Kind Regards
    Brian
  28. #428
    Wisconsin
    3,581
    118
    I just got an E-P1 yesterday and am getting it set up. I used the kit lens today to see if I could capture butterflies. I really liked the close focus distance of this lens.
    E-P1 with kit zoom ISO 100 f/5.6 1/640 seconds, RAW/C1
  29. #429
    Terry's Avatar
    New York City
    6,955
    1145
    Hey Cindy,
    Looking good. The close focus is quite a nice feature!
  30. #430
    Wisconsin
    3,581
    118
    Thanks, Terry. Here is another with EP-1 and kit zoom.
  31. #431
    1,008
    This damned camera is too good. I haven't taken many pics yet, but my wife is impressed that they are better than I was getting from my Canon 5D/5D2.
    Both pics from my soggy vacation, shot with the kit 14-42.
  32. #432
    144
    A picture from today: Lonely
    E-P1 with Kit lens at 42mm, slightly cropped.
    Karl
  33. #433
    Senior Member JMaher's Avatar
    Sarasota
    942
    16
    Friedel,
    Great colors - I love the interaction of the reds and the blues.
    Jim
  34. #434
    Wisconsin
    3,581
    118
    Quote Originally Posted by Friedel View Post
    Karl
    Karl,
    I like the interaction of the old and the new (as well as the blue and the red.)
  35. #435
    144
    Thank you, Cindy and Jim.
    Karl
  36. #436
    Jan 2009
    USA
    1,763
    45
    Hello retow,
    Nice vibrant colors as in some of Ken Rockwell's images. All the best, Leica 77
  37. #437
    Jan 2009
    USA
    1,763
    45
    [QUOTE=tom in mpls;122151]This damned camera is too good. I haven't taken many pics yet, but my wife is impressed that they are better than I was getting from my Canon 5D/5D2.
    Hello tom in mpls,
    Nice and clear details! All the best, Leica 77
  38. #438
    Senior Member nostatic's Avatar
    Jan 2008
    socal
    1,037
    On vacation in Big Bear. I really like using this camera. Shot jpg (horror!) and mostly no pp at all.
  39. #439
    Feb 2009
    83
    Hi Cindy, how are you keeping?
    Great shot with the EP1 - lovely colors and details.
    cheers
    ric
    Quote Originally Posted by Cindy Flood View Post
  40. #440
    Ithaca, NY
    3,538
    For your pixel peeping pleasure, a lily pond in Zoomify. Full size image shot with E-P1 and kit lens.
    http://www.schophoto.com/LilyPond.html
  41. #441
    Ithaca, NY
    3,538
    Orchids. E-P1 + FL-14 used off camera with TTL cable for bounce flash.
  42. #442
    Member slosync's Avatar
    Jan 2009
    Florida, USA.
    97
    I recognize those - They are rare Hikey Orchids
    Actually that is an interesting picture.... Did you replace the background?
    Don
  43. #443
    Ithaca, NY
    3,538
    Quote Originally Posted by slosync View Post
    Don
    No background replacement, just cloned out the stem at the bottom of the image.
  44. #444
    thearne3
    Greetings All!
    This is my first week with the E-P1 and I am loving it! In addition to the kit zoom, I am enjoying 3 recently acquired hexanon lenses (135 f3.2, 57 f1.4 and 40 f1.8) with Konica adapter. Here are some photos from the week....all local to the Ridgefield CT area...all jpgs minimal PP. Comments welcome!
    Tom
    14-42 zoom at iso 400:
    zoom at iso 200:
    135mm at iso 400 (cropped)
    40mm w/Art BW:
    zoom at 42mm iso 200 at 1/50th:
    57mm at iso 200 1/4 sec:
    zoom at iso 400:
    57mm at iso 200:
    The following shots are of a Pierce Arrow Phaeton circa 1930 using the hexanon 57mm at iso 200:
    http://lh3.ggpht.com/_TCWQLtc_9Zk/Sn...ersion%202.jpg
    http://lh4.ggpht.com/_TCWQLtc_9Zk/Sn...ersion%202.jpg
  45. #445
    Wisconsin
    3,581
    118
    I really like the first Phaeton hood ornament with the hexanon 57.
  46. #446
    Jan 2008
    socal
    1,037
    I"m partial to the second one. It has a yin/yang thing going on with the lighting.
  47. #447
    Wisconsin
    3,581
    118
    Quote Originally Posted by thearne3 View Post
    Thanks, Cindy. I can't figure out how to show the pics in line...I uploaded them, but there's no way to insert in the post...are they too large?
    Tom
    Tom,
    Please read this thread: http://forum.getdpi.com/forum/showthread.php?t=54 Jack and Guy explain how to post images.
  48. #448
    thearne3
    Quote Originally Posted by nostatic View Post
    Hmmm... You're right, didn't 'see' that until you pointed it out! I also didn't realize when taking the photos that the DOF was less than 1". Oh well, live and learn...
    Tom
  49. #449
    Jan 2008
    socal
    1,037
    Tom
    I wouldn't change a thing - if you went deeper you'd lose the way the background diffuses and probably much with the very cool gray/green colors on the right. I like that image a lot...
  50. #450
    thearne3
    Wink Re: Having fun with the E-P1
    Tom,
    Thanks, Cindy. I made the changes, subject to the 10 pic limit...
    Tom
