Results 1 to 3 of 3
Thread: Computar 12.5mm lens 'rattle'?
    thearne3
    I recently took delivery of a Computar 12.5mm f1.3. I have the RJ Camera c-4/3 adapter and will need to grind/shave the base of the lens to fit. As it is, it only focuses to about 3'.
    My concern is that the lens appears 'mint', but when it's shaken, it sound like something is moving inside. This sound is muffled at f1.3 and quite a 'rattle' at f16 or 'C'.
    I can't really tell if the optics are affected without going ahead and grinding the lens.
    Is this normal? or is it defective? It's not a big investment ($35), but they're getting a little harder to find at this price level...
    Thanks!
    Tom
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,604
    21
    Re: Computar 12.5mm lens 'rattle'?
    These TV lenses have components (glass elements/groups) that are screwed and fastened with a glue. Over time, heat affects that glue and it they come loose.
    No, it is not normal and it is defective.
    thearne3
    Thanks! I will see if I can exchange it...
