Results 1 to 5 of 5
Thread: R lenses for the 5D?
    Deceased, but remembered fondly here... johnastovall's Avatar
    Dublin, Texas, U.S.A.
    1,549
    112
    I can possibly get some of these cheap.
    Elmarit R 2.8/35 sn2855683
    Summicron R 2/50 sn2580742
    Elmarit R 2.8/180 sn2249444
    Vario-Elmar R 3.5/35-70 sn3318420
    Elmarit R 2.8/90 sn2414120
    Angenieux w/ R mount 2.5/3.3 35-70
    Which would be the best deal for a 5D?
    "The market wants a Leica to be a Leica: the inheritor of tradition, the subject of lore, and indisputably a mark of status to own."
    Mike Johnston
    Senior Subscriber Member Steen's Avatar
    Denmark, CPH
    2,500
    12
    Re: R lenses for the 5D?
    John, are you aware of this list of lens versions and serial numbers ?
    http://www.pebbleplace.com/Personal/Leica_db.html
    you seem to be looking at some rather old versions (optical formulas)
    1,549
    112
    No, I was not aware of that site. The person looking to sell got them from his Grandfather with an R4 so I figured they were '70's vintage. But some times older optical formulas produce nice drawing effects.
    Mike Johnston
    Subscriber robsteve's Avatar
    1,202
    496
    John:
    The Leica Lenses will probably all fit on the 5D. I am not sure about the Angeniux.
    I would avoid the Leica 35-70mm zoom. As they got old there was a lot of wiggle in the construction.
    Some of the alternative guys like the 35mm f2.8. If it is cheap enough, it is worth a try.
    The 50mm, 90mm and 180mm are probably the best of the lenses you listed. They are pretty low serial numbers, so the 50mm and 90mm may be of a design prior to the latest. The 90mm in particular had an improvement in the latest lens design. The 180mm is probably an older design, but the older design was just a bigger lens with a tripod mount and performed as well as the newer pre-APO lens.
    Keep in mind that these older generation lenses will not take standard filters, but would require series filter and filter retaining rings.
    Robert
    Senior Member doug's Avatar
    708
    Quote Originally Posted by robsteve View Post
    As far as I know this is more true of the E60 (Japan) version than of the E67 (Germany) version
    The second and third versions (Series VII or E55 filters) are the ones to watch for.
