Results 1 to 2 of 2
Thread: FS: Dual Bay hot-swap Serial ATA screamer!
    Senior Member bradhusick's Avatar
    Seattle, WA USA
    2,498
    53
    For those of you looking for really fast storage, especially good for screaming fast scratch disks for Photoshop, here's a FirmTek 2EN2 drive in excellent condition together with six drive sleds, two WD Raptor 150GB drives and two serial ATA cables. Sells new for $450, offered here for $275 shipped in CONUS.
    I will even throw in a Cardbus32 dual serial ATA adapter for free (SeriTek 2SM2-E)
    Specs:
    Dual-Bay Hot-Swap External Serial ATA Enclosure
    The SeriTek/2EN2 is a cutting-edge two-bay Serial ATA (SATA) external hard drive enclosure. It provides versatile hot-swap capabilities with virtually unlimited storage possibilities in a small form-factor package that sits neatly beside your notebook or desktop computer. SeriTek/2EN2 offers the latest eSATA shielded connectors and a whisper-quiet fan with three user-selectable speed settings.
    SeriTek/2EN2 extends Serial ATAís storage capabilities outside of the computer chassis with flexibility on par with USB or FireWire but with much higher 3.0Gbps transfer rates. Serial ATA Hard drives can easily be swapped in and out of the SeriTek/2EN2 enclosure within seconds. The two included drive trays are compatible with FirmTek's other SeriTek external enclosures.
    Allowing for true end-to-end Serial ATA capabilities, SeriTek/2EN2 is compatible with virtually all Serial ATA host adapters such as the SeriTek/1eVE4 and SeriTek/1SM2. SeriTek external host adapters, like the SeriTek/2EN2 enclosure, are designed with shielded Serial ATA ports which meet regulatory requirements for electrostatic discharge (ESD), electromagnetic interference (EMI) emissions, and susceptibility. This ensures that a good ground path between the cables and the connectors exists to prevent any ESD discharge during cable insertion or removal.
    Key Features and Benefits
    Attractive, durable design with a professional appearance
    Brushed & anodized extruded aluminum case for maximum rigidity and heat dissipation
    Provides physical lock and key security
    Power and activity LEDs for each hard drive
    High-performance storage data transfer up to 3.0Gbps (300MB/sec) per drive
    Faster than USB 2.0 and FireWire 800
    Dual hot-swappable 3.5" Serial ATA drive bay enclosure with removable trays
    Additional trays are available separately for virtually unlimited storage possibilities
    Built-in quiet exhaust fan with three user-selectable speeds for cool-running hard drives
    Surpasses rotational vibration and heat dissipation requirements of high RPM drives
    Fully RAID capable: Compatible with Operating System and host adapter based RAID solutions
    RAID arrays can span across multiple enclosures
    Works with PC and Macintosh computers with shielded Serial ATA ports running OS 8, OS 9, OS X, Windows 98/SE/ME/2000/XP/2003 and Linux
    External power adapter offloads computerís power supply
    Brad Husick
    Seattle, WA USA
    2,498
    53
    Re: FS: Dual Bay hot-swap Serial ATA screamer!
    I will now also include a SeriTek 2 port eSATA host adapter for the Mac Pro.
    That's the 2 bay drive, 6 sleds, 2 Raptor drives, host adapter, cardbus adapter and two eSATA cables for $275 shipped in CONUS. How can you beat that???
    Brad Husick
