As new in box, never used.
$100
Full spec can be found here:
https://www.olympus.com.au/Products...ernal-Flashes/FL-36R-Electronic-Flash/Section
Specifications
Guide number (ISO100/m) Automatic switching 12mm (35mm equivalent: 24mm): 2042mm (35mm equivalent: 85mm): 36
*When using the bundled wide panel, 12/14 switching
Firing angle 12mm (35mm equivalent: 24mm): 62° vertical, 78°
lateral 42mm (35mm equivalent: 85mm): 21° vertical, 28°
lateral
*When using the bundled wide panel, supports up to 8mm (35mmmm equivalent: 16mm)
Flash mode TTL-AUTO, AUTO, MANUAL, FP-TTL-AUTO, FP-MANUAL
Wireless (RC) function Can be used with cameras that support Olympus wireless (RC) flash systems.
No. of channels: 4 channels.
No. of groups: Independently controlled 3 groups.
Flash mode: TTL-AUTO, AUTO, MANUAL, FP-TTL-AUTO, FP-MANUAL
Slave function AUTO, MANUAL
Bounce Vertically: 0 to 90 degrees, Down: 7 degrees, Right: 0 to 90 degrees, Left: 0 to 180 degrees
Custom Setup AF Illuminator specifications: On/Off
Power supply 2 AA alkaline batteries (LR6), 2 AA NiMh batteries, 2 AA lithium batteries (FR6), 2 AA Oxyride batteries or CR-V3 lithium battery pack (LB-01)
Size 67mm (W) x 95mm (H) x 108mm (D) (excludes protrusions)
Weight 260g (excludes batteries)
Accessories FLST-1 Flash Stand Soft Case
$100
Specifications
lateral
