corvus
I once traced the described distortion profile for retrofocus wide-angle lenses with my modest converted Nikkor PC 28 3.5 - at the time when the camera was still available to me. It probably boils down to more or less mustache distortion with all retrofocus designs, as it has often been fathomed and described by Rob here for this type of lens.
I took a total of 9 shots with full frame 36x24mm each with 20mm horizontal shift and about 15mm vertical shift each. I tortured the lens to beyond the image circle. All in all, this is of course an extreme image angle of about 97°, which I would not use in architecture for a reasonably spatially correct representation ...
Up to maybe 55mm image circle you can use it well with some barrel distortion, which should be correctable. But beyond that, it reverses to a pillow. At the top of the attic, it's also easy to see. Right at the edge it gets extreme, as you can seefrom at the windows. The paving stones at the bottom of the image are actually roughly square ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Of course, this is just a FF lens. With MF sensors on MF lenses this would have to be investigated separately, but probably only a certain part of the image circle can be sensibly exploited for stitching. Regarding distortion, I'm tingling to one day try a symmetrical lens between 47 and 65mm. Hopefully it will work out.
![Nikkor PC 28 3.5 imagecircle.jpg Nikkor PC 28 3.5 imagecircle.jpg](https://getdpi-attach.nyc3.digitaloceanspaces.com/data/attachments/81/81580-e5fbb966e587290af64f93dd871386c1.jpg)
Torsten
![2023-08-13_133453_Nikkor28_F11_9parts.jpg 2023-08-13_133453_Nikkor28_F11_9parts.jpg](https://getdpi-attach.nyc3.digitaloceanspaces.com/data/attachments/81/81579-2c7d8c206df2b1cc5e4be9d8cb307f58.jpg)
Torsten
