MGrayson
Playing around with old lenses got me thinking about diffraction. Why? Because we often need to use f/11. When I was shooting a tech cam with a large sensor, f/11 ws kind of standard. And then there's the whole f/64 thing with large format.
But calculations of diffraction blur show that the size of the Airy disk (blurred image of a point) depends only on wavelength and f-number. For 5µ pixels, pixel level blurring becomes dominant at the same f-number independent of sensor size.
And THIS is why viewing at 100% on a monitor is dangerous. Because what matters is the final image size or, given a sensor size, magnification. Large sensors don't have to be magnified as much to make a final image, so they can afford larger Airy disks. The formula for disk size, BTW, is 1.22*f*w, where f is the f-number and w is the wavelength.
Let's make a 16"x20" print from 8"x10" film using f/64. Pick a wavelength of 6,000 Å, AKA 600nm, AKA 0.6µ, a nice Yellow. This gives us an Airy disk of size 1.22*64*0.6µ = 47µ. That looks like a large number, but when we make our 16"x20" print, that becomes only twice as large, so 94µ = 0.1mm = 1/250". In other words, we get 250ppi resolution.
Let's do the same thing with a 645 digital back at f/11. The disk size is 1.22*11*0.6µ = 8.1µ, and that's like one to two pixels depending on the back. But our sensor is a bit over 2 inches and we need a magnification of at least 9 to make the print, so the spot becomes 75µ. Better, but not hugely better than Ansel Adams at f/64. We could even get away with f/13.
And, as most of us have 44mmx33mm sensors, we get a magnification of 12 and so a disk size of 96µ in the final print. Almost exactly the same as the 8"x10" film at f/64.
Of course, modern lenses are sharp at lower f-numbers, but I wanted to see what corresponded to the historical gold standard. And if you've ever seen a 16"x20" print in person of "Clearing Winter Storm", or "Moonrise, Hernandez", the last thing on your mind is "meh, could have been sharper."![ROFL :ROFLMAO: :ROFLMAO:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Matt
This, BTW, is George Biddell Airy. He's also the guy who chose Greenwich as the location of the Prime Meridian.
![Airy.jpg Airy.jpg](https://getdpi-attach.nyc3.digitaloceanspaces.com/data/attachments/86/86896-abdce3af8928d1ef2e35c9cd0eeda098.jpg)
Matt
