Freezing T.01 speeds of Broncolor Pack as compared to 2 other brands for product photography
Allthink_
Hello colleagues
Some dissapointment after acquiring Grafit and Verso pack.
I have a question for those of you that used Broncolor Grafit A4 or Verso A4 packs.
I had an impression that these packs have very fast t.01 times, but after acquiring both packs, I'm not sure, maybe you can confirm?
I'm interested in 150-600w/s range for products.
I saw that some photographer was getting these numbers
at 100Ws 1/5600s
at 132Ws 1/4000s
at 214Ws 1/3000s
at 300Ws 1/2600s
at 320Ws 1/2300s
at 500Ws 1/1500s
But that's not what i see is written on the pack. Either the pack "lies" and in reality the speeds are much better or it's the reality.
When I attach 1 or 2 pulso 3200j (one F and one G) heads, on my unit it says t.01 1/1870 on minimal power 3.3 level and it gets worse (slower) as I raise the power. So it's not in the line of what I saw from another photographer.
I don't have Sekonik that measures t.01 speeds, only regular meter, so can't check this too. On verso, It doesn't show t0.1, so I even don't know , only on Grafit it's showing.
How can it be? I need freezing power of 1/2500 at least, and 1/1870 is too slow.
I have some Elinchroms d-lite and BRX, but they are slow.
Also I have Qodox QT 1200, very big 1200w/s units monolights, and they give me these speeds in speed mode
1/300-1/23400s (Speed mode)
1/16(75ws) power - 1/6170s (1/6540 advertised)
1/8(150Ws) power - 1/4190 (4270 advertised)
1/4(300Ws) power - 1/2360
1/2(600Ws) power - 1/1130
Official data on brochure says 1/80 - 1/6000 s, so that's in line of what i saw from some photographer- at lower power levels(150-300ws)
So, if you have any of these packs or at least know from past experience using them, can you confirm/check what are the real speeds? It just doesn't make sense that I see good t.01's at some other photographer, but when i finally buy this used units, i'm not getting these number i hoped to get.
I thought these 2 units (without going to more expensive Score) will be the best buy for freezing stuff.
Maybe i got unit with burned capacitors that give me slower speeds?
Your knowledge will be helpful if you can check.
Ben730
I don't have a Grafit pack to hand for the next few days, so I can't check my statement, so I have to write from memory:
The minimum flash duration of 1/6000s can only be achieved with a single Pulso flash head at Power 3.7 or 3.8, (not 3.3).
If you connect two Pulso heads, the time is extended because you need more power.
I therefore own several Grafit Packs.
You can achieve maximum output from a single light with a Pulso Twin connected to two Grafit A4 packs.
Hope that helps,
Will Deleon
What are you trying to freeze? I've worked with both Grafit and Scoro (which I own) and they both have been more than capable of freezing anything at moderate power levels. I'm usually iso 50, F8 on most of my shoots.
Allthink_
For example water droplets.
Oh, I think i managed to understand what was the issue myself.
When I was using a test, i did connect 3 heads and also was in opt mode.
I then switched to 2 heads and to 1 head, in both I did get high t0.1 speeds but only in min mode.
I currently have Verso and Grafit and 2 other brands that are monolights. Have to add 1 additional Pulso F/G head to have 4.
Also I have to check their shifts on White balance. If they will be >500 Kelvin, i think I will have to use only one brand.
Ben730
I now was able to check. With power 3.8 you can get t 0.1 = 1/7500s with a Grafit A4.
In this setting you should get a significant shift towards blue.
If you have the Colormeter FCC you can change precisely the color shift of the flash in 50deg steps resulting in shorter flash duration.
Allthink_
Thanks Ben
I was doing a freeze test with vent, the verso and grafit were giving yellow/red tint, grafit in min mode. And what's interesting, in regular mode on grafit, green tint.
Even on the fastest settings like 1/7000, and even that the vent was in 2nd speed out of 3, still motion blur on vents accured. I assume, it it was 1/10000-1/14000 , it was pretty frozen.
Allthink_
I see, the only way to get a "more correct" white balance/less shift, is to lower the flash power, is that what you mean? I sadly don't have colorimeter that measures the t.01 speeds and color /shift. But it will require to deal with that in post.
Allthink_
Ben, I have a question to you.
How many seconds it takes your Grafit to recharge when you go from higher to lower power levels?
On my unit, it's pretty fast as i go up in power, but around 10 -15 seconds if i go lower (either 1/10th or 1 stops). Is it normal?
Ben730
Yes, this is normal. The internal discharge takes some time.
If you want to speed it up, you can test flash a few times to discharge.
