Hasselblad 100C and 35XL
tenmangu81
I've briefly read this thread, and can't understand why the 100C could give rise to banding when used with a tech cam, while the 50C won't. One of the differences between the two DB is PDAF, and I've read that it could be one of the reasons. Could somebody explain me why ?
I don't know much about tech cams :rolleyes:
MGrayson
I'll give the high-level stuff. PDAF is an automated software split-prism. One short strip of pixels looks only at the left side of the lens, another - located in the same place on the sensor - looks only at the right. If that spot is in focus, the two strips will line up. If one is shifted with respect to the other - just the way a split prism image is when not in focus - the software figures out the best way to move the lens so that they will match.
With an SLR (the key letter being R for Reflex), this happens away from the image sensor on separate focus sensors. On mirrorless, the focus sensors are built into the image sensor. That means that some pixels are different, and that difference needs correction in the imaging pipeline. When that correction fails, lines appear. It must be shift-dependent.
That's all the detail I can give.
Matt
(The name Phase Detect comes from the correlation between the two strips under different shifts. When they match most closely and the correlation is high, they are "in phase". This is exactly how you would determine the phase of a signal. You shift your test sine wave until it best matches the signal sine wave. That offset is the phase. On a camera, that offset is how much the focus motor has to move.)
MGrayson
Oh, a data point. I just took this - posted in Fun with MF Images 2024 - with a Mamiya 645 50mm lens shifted 12mm on an X2D (same sensor) with even more extreme processing than shown here - 100% Dehaze, 100% Clarity, and contrast boost - it shows no lines in the upper corners. Now the rear element of that lens is quite far from the sensor, as it was designed for a 645 reflex camera. I note, also, that the shift here is parallel to the lines, so that may help mask them.
Matt
Bill_Evans
Has anyone who moved up to the 100C from the 50c started using this new back in their production tech cam workflow? I'd be interested to hear how the trade-offs measure up. Specifically the reduction in color casts, and maybe tiling of the wide Schneider lenses, vs this new "feature" of PDAF lines. The 50c doesn't seem to be without its workflow needs, ie LCC & shift limits. Curious if the new back is DOA, or just a new set of workflow hurdles.
tenmangu81
Looks like the last version of Phocus has just been released. Maybe they address the issue of the stripes with T/S, in the same way they did with the magenta cast observed with the XCD28P. Dreaming is always possible....
chriswebb
New features in 3.8
HEIF support
  • With X2D/CFV100C FW 3.1.0, it is now possible to capture to 10-bit HEIF format.
Phocus 3.8 adds comprehensive import and editing support for Hasselblad HEIF​
images. With few exceptions, Phocus editing tools work for HEIF as they do for RAW.​
Editing HEIF is non destructive as changes are stored in sidecar files.​
Vignette correction and scene calibration is not supported for HEIF files.​
Performance enhancements
  • Viewer performance has been improved resulting in smoother and more precise editing, particularly when using the exposure tool.
  • Performance of thumbnail browsing has been improved, keeping Phocus responsive even when working with large numbers of images.
  • Multi-shot images also enjoy faster render at 100% zoom and export.
Support for new hardware
  • This release introduces support for the new 907X CFV 100C camera.
General improvements
  • A large number of fixes and stability improvements have also been included in this release.
No mention of any specific fixes for this issue. Also the new release appears to only be for Macs so far.
f8orbust
Given the nature of the issue, I don't think we'll see it fixed via a firmware update, so my guess is it will be addressed in the next major Phocus update across both Mac and PC - i.e. 3.9 or possibly even 4.0.
Schafphoto
Yes, I agree, nothing is perfect. But I have clients who depend on this equipment for their livelihood, have been using similar equipment in similar ways for years, and have not had this issue previously. Avoiding using the camera this way is not an option for them.
Steve Hendrix/CI
I am waiting for Hasselblad to work out this banding issue before purchasing the 100C and reacquiring a Hasselblad digital system as an upgrade from a Canon digital system, after abandoning my Hasselblad 203FE analog in 2005 (loved that camera) fortunately I kept the 40mmFLE. The use of the 100C on an Arca tech cam with wide lenses for architecture with significant shifts and correctable LCC/CA/distortion/banding anomalies is paramount before purchasing. Using only one batch post production/RAW software before cataloging the captures in Lightroom would be nice.
Given that the Techart adapter may not *yet* be updated to work with the 100C yet, I would be very interested in knowing if anyone is using this back currently with Canon (TSE) lenses. Perhaps Canon TSEs are a little less susceptible to the banding because they are a little less symmetrical (more retrofocus).
vjbelle
I hope you are right..... the latest software update does not address it but it's kind of moot for me as my Rody 50mm F4 is about as wide as I need and I cannot detect the banding with that lens. My Schneider 35XL is susceptible but I've given up using that lens as the lolly GF 35-70mm lens is better at the 35mm even with software fixes for keystone.
Even so I would like to see a fix from Hasselblad....
Victor B.
anyone
I just finished adapting my Digitar 180 to the Cambo. Upside: it all works as expected mechanically.
Downside: I just discovered these darn banding stripes on the LCC…
Edit: Cross that comment. I now just looked at the files and it does look like ES in combination with an artificial light source, I might have had one lamp on in the room.
Apologies for the confusion.
vjbelle
I have not seen any banding with my CFV-100C with any lens I have 50mm and longer (Rody 50mm, Schneider 72mm, Rody 90mm, Schneider 100mm, Schneider 120 Asph, Rody 138 Float, Schneider 180mm. I can certainly detect it with my 35XL but that is it.
Victor B.
