Here some specs leaked on a FB group:
Hasselblad X2D 100C 100MP Medium Format Mirrorless Digital Camera Body -
Battery - 30W USB-C Charger - USB-C to USB-C Cable - Shoulder Strap -
Battery Cap - Quick Start Guide - Hasselblad 1 Year Limited Warranty
Key Features . . . .
· 100MP Medium Format BSI CMOS Sensor
· IBIS - 5-Axis
7-Stop In-Body Image Stabilisation
· Phase Detection Autofocus (PDAF)
· 1TB Built-In SSD
· 15-Stop Dynamic Range
· 16-bit Color Depth
· 3x Faster Focusing
· 97% PDAF Coverage
· 3.6" Touch and Tilt Display
· 2.36M Dot Resolution
· 65% Faster Shutter Response
· 70% Decrease in Blackout Time
Specifications . . .
Camera Type - Medium Format Mirrorless Digital Camera with autofocus,
auto-exposure, interchangeable lenses
Material - Machined Aluminum. Tripod socket 1/4"
Sensor Type - Back-side illuminated (BSI) CMOS, 100 megapixels (11656 x
8742 pixels, pixel size 3.76 um)
Image Size - Stills: 3FR RAW: capture 206MB on average
File Format - Hasselblad 3FR RAW, full size JPEG
Drive Mode - Single and Continuous Drive, Self Timer, Interval Timer,
Exposure Bracketing
Color Definition - 16-bit; dynamic range up to 15 stops
Image Stabilization - 5-axis 7-stop in-body image stabilization (IBIS)
SO Speed Range - ISO Auto, 64, 100, 200, 400, 800, 1600, 3200, 6400,
12800, 25600
Storage Options - Built-in 1TB SSD. Extra CFexpress Type B card with a max
storage capacity of 512GB supported.
Color Management - Hasselblad Natural Color Solution (HNCS)
Capture Rate - 3.3fps in a 14-bit color depth
User Interface - Touch interface including swipe, scroll and pinch/spread
to zoom. Camera grip with buttons and scroll wheels.
Touch Display - 3.6" (9.14cm) TFT type, 24-bit full-color,
2.36-million-dot. Touch functionality: full support. Tilting angle: 40
Degree , 70 Degree
Top Display - 1.08" (2.74cm) TFT type, 18-bit full-color, 158,400-dot
Electronic Viewfinder (EVF) - OLED, 5.76-million-dot. Viewing area: 100%.
Magnification: approx. 1.00x with 65mm medium format lens at infinity,
-1 m
Histogram Feedback - Yes, in Browse mode on touch display and in EVF
IR Filter - Mounted in front of sensor
Software - Phocus is compatible with computers with 8GB of RAM or more
running on macOS 10.15 or later, or Windows 7 64-bit or later. Phocus
Mobile 2 is compatible with iPad models with 3GB of RAM or more and with
iPhone X or later models running iOS 14.0 or later.
iOS Device Support - iPad models with 3GB of RAM or more and iPhone X or
Platform Support - macOS 10.15 or later, or Windows 7 64-bit or later
Host Connection Type - USB 3.1 Gen2 Type-C connector (transfer speed up to
10 Gbit/s)
Operating Temperature - 14 Degree to 113 Degree F (10 Degree to 45 Degree
C)
Operating Humidity - No more than 85% without condensation
Wi-Fi - 802.11b/a/g/n/ac/ax, Wi-Fi with 2x2 MIMO
Supported Lenses - Hasselblad XCD lenses with built-in electronically
controlled leaf shutter and aperture. Automatic or manual focusing with
instant manual focus override. Lens shades can be mounted in reverse for
transport.
Compatible with all H System Lenses and some H System accessories using
the XH Lens Adapter.
Also compatible with V System and XPan Lenses using the XV or XPan Lens
Adapter.
Shutter - Electronically controlled leaf shutter with speeds up to 1/4000
s. Flash sync at all speeds. Optional electronic shutter
Shutter Speed - 68 min to 1/4000 s with XCD Lenses. Up to 1/800 s or
1/2000 s with HC/HCD Lenses. Electronic shutter 68 min to 1/6000 s.
Flash Sync Speed - Flash can be used at all shutter speeds. Mechanical
shutter only.
Flash Control - TTL centre weighted system. Compatible with Nikon System
flashes. ISO range 64 to 25600. Flash output can be adjusted (-3 to +3
EV) for fill-in purposes independent of ambient light. Sync at all
shutter speeds. Mechanical shutter only.
Flash Compatibility - In TTL-mode, the following Nikon Flash products can
be used: SB-300, SB-500, SB-5000, SB-700, SB-900, SB-910. The following
Profoto products can be used in TTL-mode: A1, B1 and B2 with Nikon
interface.
Focusing - Autofocus single (AF-S) and manual focus (MF). Instant manual
focus override. Automatic focusing using phase and contrast detection.
Focus indicator, 100% zoom, or Focus Peaking available in MF. Up to 294
Phase Detection Autofocus (PDAF) zones.
Exposure Metering - Spot, centre weighted, and centre spot
Power Supply - Rechargeable Li-ion battery (7.27 VDC/3400 mAh). Can be
charged in-camera via the USB-C port on the camera body. Charging time
is approx. two hours using the included 30W USB-C charger.
Recommended Memory Cards - Sony CEB-G series CFexpress Type B memory cards
SanDisk Extreme Pro CFexpress Type B memory cards
Battery Info - Required, included
Battery Material - Lithium ion
Battery Type - Non-universal
Battery Quantity - 1
Dimensions - 5.84 x 4.17 x 2.93" (148.5 x 106 x 74.5mm)
Sensor: 1.72 x 1.29" (43.8 x 32.9mm)
Weight - 31.57 oz (895g) (Camera body with the battery)
27.86 oz (790g) (Camera body only)
Item Highlights. . .
· IBIS - 5-Axis 7-Stop In-Body Image Stabilisation
· 1TB Built-In SSD
· 97% PDAF Coverage
I privately talked to the guy, he is a pro, he seems genuine...apparently got the info from his dealer which got it today from H
We shall I see!
Iso 64 would be amazing!!!!
