Alkibiades
Old question, what is more important, more pixel or a better lens?
Afcouse better lens and more pixel will be the best option, but ...
I made now a short comparison of a good lens on 100 MP and an excellent lens on 50 MP back. Afcourse it would be the best methode to use the same lens on both systems, but this is the practical compatibility problem.
Sadly I can use the one lens only on the one system and the other lens on the second.
The first one is the Fuji GFX 100S with the most used wide angle focal length 35 mm.
And the lens that I need must be a shift lens that allows me movements, standart wide lens is useless for me.
As long as Fuji cant deliver the new 30 mm Shift lens I use an old but still very good and very known Zeiss Distagon PC 35 mm.
It was made for Contax, one version as a shift lens for Contax 35 mm and one version as a Wide angle with no movements for Contax 645. Both share the same lensdesign accept one additional lens element conditioned by the different camera mount.
The lens is still one of best existing 35 mm for 645 Format, even it is an old Film lens.
I use the lens on Fuji 100S becouse there is no other option for me and this lens close the gap between canon 24mm TS-E II and 50 mm TS-E.
This combination allows me a very fast and spontaneous work with great mobility.
17 TS-E and 15 Laowa can help at special use, but is mostly too wide.
Zeiss Distagon was a great lens on my Sony FF sensors and allows me still on Fuji100S full 10 mm movements in almost good quality.
But I wanted to know if the 100 MP combo is better than a 50 MP back with the best 35 mm available.
I can use my Phase one 250 with Digaron-W 4/32 mm HR and Digaron-S HR 4/35 mm and both lenses are simply the best lenses in this range. The sharpness, resolution and performance at the edges are simply on other level.
With the smaller 33x44 mm back I even prefer the Digaron-S 35 mm as the lens is much smaller than the 32HR.
So I take a pictures with both systems from the same position, both shifted 10 mm, no correction, no LCC, no sharpening, both files develope in capture one.
