Hi, Jotloob, Thanks,Sunchai
A very nice and interesting gear . Looks to be machined very well .
But you should give detailed info about the function .
On top of the rear standard and front standard of the carrier have built in the Arca clamp style
So any arca compatible plate can be mounted on the top of both standard.
However, the main designed is to carry the Smart Flex-L Plate and there compatible camera.(P1,Leica,Canon,Nikon,Sony,Pentex and…) and it can take the digital back with add on accessory as showing with the attached image.
*The geared Swing Tilt with Lens holder unit can be mounted on top and easy take off from Front Standard this should reduce the size will make the unit compacted when travelling
*lens holder it will working with Has. RZ. RB. and copal 0. Lens.
*Double focusing with double rail system, Front focus by normal gear and rear focusing by lead screws which slow movement and will more precision focus. The rail on rail system also make it compact size and can be extend when need.
*Both Front standard and Rear standard can adjust for Rise and Fall by 14mm /14mm.by geared and slide shift for left and right by 14mm./14mm.and the smart Flex unit can do also the slide shift by itself.
Note the attached image do not show the bellow which is need, I think without bellow it is more easy seen.
Sunchai.
Dan
I discover a bellows hood , i have not seen before . Can you please give some details and who makes that system ?
Thank you .
Why was the lens delayed by Rodenstock and rejected by ALPA ? ? ?First time poster here.
So finally, after 2 months of waiting, I recieved my "starter" set, the 32 has been delayed by Rodenstock and rejected by ALPA, but finally I got everthing on Xmas day!
So finally I can join the club here, now just need to find time to go out to take pictures![]()
As Alpa 'starter' kits go that's no too shabby! Starting with the best on all fronts by the look of it. :salute:First time poster here.
