Results 1 to 11 of 11
Thread: Which Bag for S2 and two lenses?
    Member Petster's Avatar
    May 2011
    83
    Hello,
    I'am currently looking for a shoulder bag for the S2. One lense mounted, one spare... and maybe space for a third lense. I'am a big fan of the quality of TTP bags and do have the Retrospective10 in mind. But as where I'am this is not available atm I do need something else. It should not look like a photobag but should fulfill all the reqs you need for carrying around your cam. Any recommendations?
    Thanks,
    Pete
    Germany
    3,623
    Re: Which Bag for S2 and two lenses?
    I know its not a shoulder bag but I really like the Sling-O-Matic which works perfect for an S2 with 1 lens attached and 2 additional + some room for a small flash or something else.
    Its very good protection, it carries well for the weight, it has a large "door" and is very good to access, and it still doesnt look/feel to big.
    IMO the prefect bag for the S2.
    You cn fit in the S2 with attached lens and hood in case of the 35,70,120. The 180 you have to reverse the hood if the lens is attached on the camera.
    May 2011
    83
    @t_streng: Do you talk about Sling-O-Matic 10?
    Germany
    3,623
    Quote Originally Posted by Petster View Post
    no, the 20 (or 30 if you want to carry a Notebook as well).
    if you like I can post an image showing how everything fits into the bag.
    May 2011
    83
    Quote Originally Posted by t_streng View Post
    This would be nice.
    Workshop Member glenerrolrd's Avatar
    Jupiter FL/Atlanta GA
    2,279
    I use two bags . Almost any standard DSLR bag can be used just for the body and the 70. The 2nd bag is either the Think Tank Lens Bag (for 2 lenses) or a Billingham Hadley Large set up for three lenses. The key is that the Lens bag is tall and set up to leave the hoods on . This allows you to carry the camera and lens over one shoulder and the lens bag across your chest and on your hip . If I want 3 lenses I set up the Billingham with a large center sleeve.
    This really works for shooting and short trips . For travel/air etc . I would pack the system for protection and stuff the lens bag (empty) in my luggage .
    You carry minimal weight and have 3 or 4 lenses ready to shoot.
    Senior Member GMB's Avatar
    Oct 2008
    Heart of Europe
    396
    I second this recommendation. I used the Sling-O-Matic extensively on a recent trip. Great back for the camera with one lens and to extra ones.
    2,800
    In a backpack I would venture the Lowepro Flipside 400 AW...opens up inside so that the harness and contents are not exposed to the ground.
    In a waist pack I prefer the Lowepro Orion AW...converts from a backpack to a beltback...probably only a three lens solution.
    Both overbuilt and heavy but great protection
    Bob
    860
    76
    I have been very happy with the Think Tank Retrospective 30 shoulder bag. I have the bag arranged so the S2 with a lens mounted (e.g., 70mm) fits in the center area with the 35mm and 180mm on each side within the main compartment. The two front pockets can expand to be rather large. Then rear pocket holds an iPad easily and would hold a small laptop as well. I have never used the outside end pockets. The only problem with this bag is that you can put so much stuff in it that it gets very heavy. It is comfortable to carry and easy to shoot out of (e.g., changing lenses and getting to accessories). Plus, it's appearance doesn't scream camera bag.
    May 2011
    83
    Thanks for all the recommendations.
    @Mark, do you think the Retrospektive 20 will work with two lenses?
    Thanks,
    Pete
    860
    76
    Pete,
    Yes, I think it will work fine. I chose the Retrospective 30 because I preferred the lower profile and I had a 3 lens kit in mind when I bought it. The internal dimensions for each bag are provided below. Both bags weight the same. A difference I see is the 20 has 1 outside pocket and the 30 has 2 outside pockets.
    The 20 would probably work better if you have 180mm mounted on the camera. This combo will fit in the 30, but the 20 is taller so should be better in that respect.
    Retrospective 20
    ID: 12” W x 11.75” H x 6” D
    Retrospective 30
    ID: 15” W x 9.5” H x 6” D
