Results 1 to 8 of 8
Thread: Pentax 67 45mm lens +zoerk PSA on mamiya DF MFDB ?
    May 2009
    Marseille, FRANCE
    972
    Is anybody tried this combo with a MFDB ?
    i'm dreaming of a really good 45mm Shift lens for my DF... i wasn't impress by the discontinued Phase one super rotator... i have a good sample of the vintage 50 mamiya PC... but i'd like a 45 or 40...
    Zörk Pro Shift adapter
    Aug 2012
    37
    Re: Pentax 67 45mm lens +zoerk PSA on mamiya DF MFDB ?
    The 45 has some really "bad" (some) distortion going on. Not so easily fixed in post. But I'm speaking of full frame (6x7) use.
    May 2009
    Marseille, FRANCE
    972
    strange, i've read in many places that the 45 was really good in respect to distortion !?
    Aug 2012
    37
    I used the 45 for a lot of my documentary projects. shooting landscape I would say you hardly will see the distortion if you don't know where to look. But with straight lines in the picture, like poles or columns, you will see it.
    In comparison the Mamiya7 43 mm and 50mm are free of any distortion.
    I'm talking about full frame use on a 6x7. I guess shifted the distortion looks even more weird than centered in the frame.
    Aug 2012
    37
    found this on the internet: "the 45 does have a tad of distortion, but not noticeable in people photos. If you have a lot of straight lines you might want the 55"
    Berlin, Germany
    143
    Quote Originally Posted by archivue View Post
    I'm fairly sure the adapter will not work on the DF, as it only works with the schneider lenses. It will work on a Mamiya/Phaseone AF though. You should check with Phaseone/Mamiya to be sure.
    Hong Kong / Asia
    524
    Quote Originally Posted by kipling View Post
    The DF does not only work with Schneider lenses.
    There is discontinued old Mamiya 50mm shift lens, which some have found sharp. Suggest you do a search here on getdpi. It is also your cheapest option. Stopped down metering of course, but so are the other options.
    Best regards,
    Anders
    Feb 2011
    W. NY, close to Toronto, far from NYC
    1,426
    9
    I used the 45mm on a 67 film camera with success and then tried it on the 645D. Very sharp, with CA in the corners. The CA should be correctable. You should be able to find one for $400 USD, worth a try. If I had a Zoerk for the 645D, it would certainly be a lens I would try for stitching; as it is, I use the 645 45-85mm zoom.
