Craig Stocks
I searched in the forum and didn't find an answer. Is anyone using that combination? Can you confirm if it vignettes with the 35mm LS? Thanks.
This shows the SW150 Ring.Can anyone using this system for their LS35 post a photo of the setup? TIA.
This shows the SW150 filter holder also on the SK35mm. Note that the filters will sit flush with the front of the lens due to the 'depth' of the ring.
This shows the Lee 105mm polariser mounted on the lens filter thread. (Please excuse the dust)
Both systems work fine and I cannot see any vignetting. The only reall drawback is that the filter rings are a bit bulky if you have lenses with different filter threads.
It's mainly the center filter that messes things up, when I asked ALPA for a lens shade solution for the 32 + center filter, they just told me to try the Lee holder :loco:I used the 86mm SW150 ring with the 32HR - it works fine. (Although I didn't use the CF with my 32Hr).
It took me a long tme to work it out and the Lee website is minimally helpful but this setup works fine both with and without the CF and the appropriate SW150 holders (I also have the HR32m). People do advise against adding weight to the front of this lens though.It's mainly the center filter that messes things up, when I asked ALPA for a lens shade solution for the 32 + center filter, they just told me to try the Lee holder :loco:
Anyway, seriously considering to try this Lee combo...
You're absolutely right about the Lee website....so thank you for being the guinea pig on this one :salute:It took me a long tme to work it out and the Lee website is minimally helpful but this setup works fine both with and without the CF and the appropriate SW150 holders (I also have the HR32m). People do advise against adding weight to the front of this lens though.
