What is "RM3D"?hi,
what's the best i-phone's holder for RM3D nowadays ?
Ah, thank you.
And what would you be doing with an iPhone in the context of an RM3D that required an iPhone holder?
what back are you using on the Arca?hi,
...indeed, I was going to chip in, if you're planning on using Wi-Fi (or HDMI) and live view, then the RRS will be a nice option since with the micro ball head, you can adjust your iPhone to almost any angle, but if your back doesn't have this capability, then the iPhone must be properly aligned with your lens / camera, so your options will be limited, and I don't think even a hot shoe will be very accurate in terms of physical alignment, I get the feeling there's always lots of play possible.what back are you using on the Arca?
Thank you! Now I understand... Had no idea. Very interesting!using an app like alpa or artist viewfinder the iPhone becomes a nice viewfinder !
https://www.getdpi.com/gallery/files/1/1/cambo013.jpg
Aptus II 7 aka DM33what back are you using on the Arca?
Be carefull, you'll not be able to fix it to the arca, all system have their own plateform....arca fit on arca, alpa on alpa cambo on cambo...or you will need a custom adapter, no sure it is a good idea, you should just buy the arca one or the jlm one.Aptus II 7 aka DM33
i've test the IQ160 and while the live view was fantastic... considering my use and my lenses, i wasn't completely convinced... and i can't afford an IQ300... so for architecture, i stick with the DM33 for now !
And considering how low is the business in south of france, i'm also considering going back to full frame... Nikon + PC-E...
I think i will go with the cambo : https://www.cambo.com/en/wide-rs-series/wrs-1060/
there's no arca's iPhone holder...Be carefull, you'll not be able to fix it to the arca, all system have their own plateform....arca fit on arca, alpa on alpa cambo on cambo...or you will need a custom adapter, no sure it is a good idea, you should just buy the arca one or the jlm one.
It looks like the iPro case is threaded at the midpoint of the case. Ideally, you'd want to be able to place the iPhone's lens at the center of the camera so that it is not offset from the lens. The ALPA and Arca allow for this placement. See ALPA SDH Mk II iPhone-Halter
First i was in the process to buy it, while i think that it's a great case, and the fact that you can use the same lens on different models suits me... but considering the support itself, i want something more precise this time.Rather than some large, unwieldy, contraption, I highly recommend the Schneider iPro case (and lenses if appropriate). The case is made by "Element Case", arguably the best iPhone case maker in the biz. Look them up.
