ErikKaffehr
DPReview has published a "first look" review of the X1D, including raw samples. So I checked them out, what did I find?
First I looked at top left corner. It contains a USAF test chart. Although USAF charts have bad reputation I feel they are quite nice and actually give a lot of good information. The cameras I choose here were:
So, what did I see? The Fuji GFX is not very sharp in the corner. The X1D is nearly perfect. A big surprise is that the canon 5DsR with it's cheap 85/1.8 USM keeps up so well. The IQ3-100MP has twice the MP and it shows.
Now, let's look at aliasing. There is an area of the DPReview test target that is aliasing hell. Here I switch to comparison mode, that shows the IQ3-100 MP image downscaled:
Both the X1D and the GFX shows a lot of colour aliasing, indicating that the lenses outresolve the sensors. Well I guess Fuji was serious the lens was designed for 100MP. The Canon lens is probably a good match for the 50 MP sensor on the 5DsR. Some aliasing but not a lot.
Looking at the fine text:
Although the IQ3-100MP is robbed of it's resolution advantage, the benefits of the megapixels is clearly seen, even the finest text is excellently readable on the IQ3-100MP image downscaled to 50 MP.
Medium ISO noise in the darks. Here, I replaced the IQ3-100 MP with with the 42 MP Sony A7rII:
At 640 ISO and above, the Sony has a small trick in it's sleeve. Sony's late generation sensors have dual gain conversion.
The 44x33 mm sensors have 68% surface area, so they should have something like a 2/3 EV advantage. Lenses for the smaller formats are often faster and the Sony A7rII has image stabilisation.
I have also run some MTF tests at the centre, where we have wedge usable for SFR analysis. At the centre the GFX and the X1D were amazingly close. The Canon was just a bit behind, while the Sony was far behind. The IQ3-100 MP was quite a bit ahead the pack.
So, what is my take? The Hasselblad X1D and the Fuji GFX seem to be yield excellent quality and they will improve a lot when the new 100MP 44x33 sensors from Sony arrive. Personally, I am quiet a bit impressed by the Canon 5DsR using the 85/1.8 USM lens.
The IQ3-100MP is clearly ahead. That may change with 100 MP arriving in 44x33, but high end MFD is not standing still.
Anyway, the X1D and the GFX seem to be able to deliver great image quality at a competitive price. The Fuji GFX 63 mm lens looses some sharpness across the field. Off axis the X1D lens tested by DPReview may be a better choice. But, a test with a single lens doesn't tell the story about a full system
Best regards
Erik
- The X1D, the new Hasselblad
- The Fuji GFX, it's closest competitor
- The Canon 5DsR, same megapixels
- The Phase One IQ3-100MP - the real king
Best regards
Erik
