Kipon is shipping tilt and shift adapters for GFX and X1D
Januarys_LP
You see the 1 larger ridged button, that controls tilt. Loosen to tilt, tighten to lock in place. The smaller round buttons below allow you to rotate the rear (camera body) or front (the lens).
Does anyone know if the above means that one can rotate and use tilt and shift parts of this adapter independent of each other? like in newer canon tilt-shift lenses...
thanks!
jvadasz
thanks!
All three controls, rotating the lens, rotating the body, and the tilting mechanism operate independently. One may rotate the lens 90 degrees and allow the lens to rise/fall without rotating the camera body (and vice-versa).
I am unable to comment on the newer Canon T/S lenses as I have not had opportunity to test one.
I hope that helps.
--Jeff
Januarys_LP
I hope that helps.
--Jeff
thanks for that info,
but what i mean is can you tilt down and shift down too, and then for another photo tilt down but shift sideways?
jvadasz
If I am understanding the scenario, you would tilt for focus then turn the lens (90 degrees) and set it to "fall" (shift down), then turn the lens back (90 degrees) and shift or re-center, etc. I that is the scenario then yes, that is possible. I will note that the turning of the lens requires some amount of force to do so, with Pentax lenses at least, there is a possibility to make a change to aperture or focal length as you need a pretty good grip!
Here are some images of the scenario as I understand it...
Body tilted, lens in "normal" position:
Lens rotated, shifted down (or Fall):
Lens still rotated, shifted up (or Rise):
Lens now rotated back to "normal" orientation and shifted to right. Please not that it is no longer in rise or fall. Shift and Rise/Fall are mutually exclusive. Further the tilt is only in the direction shown in my images here:
I do hope this helps you see what the adapter can do.
--Jeff
jvadasz
The scenario you describe above should work as I understand it. Below are some images I made to illustrate what I believe you are describing.
Tilt with lens in "normal" position:
Still tilted, lens now rotated and "shifted" down:
Still tilted, lens still rotated and "shifted" up (I added this though it was not part of your description):
Still tilted, lens now rotated back to normal orientation and shifted:
I do hope the is what you were describing.
--Jeff
Januarys_LP
--Jeff
thank you very much, exactly what i wanted to know!
