vieri
Hasselblad just released their FW 1.2.0 update for the X1D II and 907x. This update adds a lot of features, see below for a list of what's new:
● Video recording: Expanding the imaging options of the X1D II, 2.7K (2720 x 1530) & HD (1920 x 1080p) video capture has been added. Video can be recorded at 29.97 fps with 4:2:0 8bit colour. The 2.7K resolution option delivers improved capture of detail, whilst balancing the final video capture size.
● Focus Bracketing: Expanding the feature set of the X1D II even further, Focus Bracketing allows a photographer trying to capture a subject with very limited depth of field, such as in macro or product photography, to capture a series of exposures of their chosen subject at a fractionally different focus point in each and then stack these captures in their chosen stacking software. The photographer will have full control over the number of frames in the sequence, the step size between each capture and an initial delay to allow any support system vibration to diminish. Note: Requires lens firmware 0.5.33 or later for all XCD lenses excluding XCD 45P. XCD 45P requires firmware 0.1.24 or later.
● Image Rating: Image Rating can now be applied to all still image captures in camera, making image sorting and selection much easier when the captures are transferred to the user’s computer system.
When in image playback mode, with the capture details overlay on screen, the photographer simply presses the star button or presses the displayed stars. All ratings are stored in the metadata of the captured image.
● Expanded White Balance Tools: The menu organization and selection of White Balance presets has been improved with display of colour temperature and tint at each setting. For the most precise colour, a Picker has also been added where the photographer can sample a neutral portion of the image to balance colour.
● 2/3 stops added in Exposure Bracketing: The Exposure Bracketing function step options have been expanded to support 2/3 stops steps in addition to the existing steps.
● Auto White Balance based on captured image: Auto White Balance is now based on the captured image which means that AWB can also be used when shooting in Manual Quick Mode. It also solves the issue when working with flash in tungsten lighting where, previously, the correct white balance showed in either Live View or the captured image – now the correct white balance is present in both Live View and the final still image.
● EVF proximity sensor settings: It is now possible for users to adjust the sensitivity of the EVF proximity sensor. The improved setting accommodates users whose typical handling style does not always engage the sensor or prefer to disable the EVF completely.
● Reset custom buttons option: A menu option has been added that will allow the custom buttons to be returned to factory defaults.
● New language: Traditional Chinese has been added in the language selection.
● Combined histogram removed from information overlay option.
You can download the new FW from My Hasselblad. Haven't installed it yet, but will report as soon as I have a chance to play with it. Best regards,
Vieri
Vieri
