Results 1 to 6 of 6
Thread: Dp-1 + Ricoh 40mm Adapter
    302
    Question Dp-1 + Ricoh 40mm Adapter
    Has anyone tried or is thinking of trying to adapt the Ricoh 40 mm adapter to the Dp-1??
    I realize that this might take some modifications of the adapter, step up rings, step down ring etc.
    But, do you think that is might work??? After all, the adapter is based on a 28 mm base lens.
    Please comment.
    Martin
    Jan 2008
    North Vancouver, BC
    1,168
    Re: Dp-1 + Ricoh 40mm Adapter
    Martin,
    Off the top of my head, I think the difference in size between the sensors would dictate a larger lens would be necessary for the DP1. I suspect that you'd get some serious vignetting.
    Senior Member Will's Avatar
    Near London
    1,054
    I've tried holding the 21mm adaptor on the front of my DP1, and it worked surprisingly well, but there was image degradation towards the edges. I'll try the same with the 40mm and, if it works, post some images.
    Near London
    1,054
    Well I tried it but it wasn't pretty! The GW-1 on the other hand wasn't all that bad.
    These are all straight jpg conversions with no pp
    28mm
    40mm
    21mm
    Lili's Avatar
    2,527
    Interesting Will
    It worked far better than I'd have expected
    302
    It could work- sort of.
    I may just try it.
    Just received the DP-1, and took some uninspired images.
    But, the sharpness, and resolution were great from this little, slow, kind of kludgy box.
    The UI definitely needs work.
    The lack of IS was not noticed since I took some interior shots at 1/6"(??) that were surprisingly sharp. Go figure???
    Martin
    Martin
