Pin sharp across most of the frame using the 18-200mm Tamron on a Nex-7. Simply a near perfect combo, as Hot says. Some distortion to deal with but less CA.Cool: outstanding at this size—how do they hold up bigger? Very nice—I am assuming that you like the lens?
I believe this only allow M mode for flash trigger and how do you use the viewfinder at night with the viewfinder/LCD turn dimmer to compensate the flash?YONGNUO flash, less than $50, power 7 steps, slave function ...
Thanks Vivek.Yat, As Douglas pointed out earlier in another discussion, you can set the "setting effect" to "Off" to make the LCD/EVF usable.
