Results 1 to 4 of 4
Thread: What is the next NEX?
    May 2012
    2,057
    So many opinions on which current camera is the best for use with wide and telephoto Leica M lenses. So will the next NEX be better? Any solid rumors?
    Of the current choices which is best for mu uses?
    NEX-7
    NEX-5n
    NEX-5
    Probably missed one.
    Also which is the best NEX to M adapter? Novoflex?
    I am new to Sony, but after buying the RX-1 they have got my attention. Since the new M has no option to move magnification around the frame to check difference focus points I am exploring other options.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,604
    21
    Re: What is the next NEX?
    Lou,
    Wait for a FW update of the M. If you really can not, consider the rumored 7n, if you can not wait another month or so, consider the 6.
    etrigan63's Avatar
    Earth, Sol System (near Miami, FL)
    2,501
    21
    Novoflex adapters are excellent, but pricey. Fotodiox Pro adapters are more reasonably priced and are guaranteed to infinity focus.
    Carlos Echenique | Carlos Echenique Photography |Olympus OM-D E-M1 MK II | Olympus Pen-F - M.Zuiko 17mm f/1.8, M.Zuiko 25mm f/1.8, M.Zuiko 45mm f/1.8, Rokinon 12mm f/2 NCS, M.Zuiko 75mm f/1.8, M.Zuiko 12-40mm f/2.8 PRO, M.Zuiko 40-150mm f/2.8 PRO
    Senior Member JohnW's Avatar
    Jun 2009
    640
    I use the Nex 7, which is definitely NOT considered the best for Leica wides. Everything I've read says the 5 handles Leica wides better.
    You might check Huff's and Reichman's sites, who have both written about this.
    John
    John
