Results 1 to 11 of 11
Thread: Desensitizing the EVF eye sensor
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    If you struggle with the LCD/EVF switch (when set to auto) from the eye sensor being too sensitive, it can be easily taken care of. Just block ~ 1/3rd of the eye sensor with a tape (electrician variety)on the left hand side. It is very effective.
    Thanks 6 Member(s) thanked for this post
    Dec 2013
    London
    590
    Re: Desensitizing the EVF eye sensor
    thanks it seems to work
    Mar 2010
    91
    Is there any way to get the monitor to stay on when you put a T-shirt around the camera so you can see the screen better in bright sunlight? Like when looking at the ground glass on a view camera? The A7RII monitor goes off when I try it.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    You can change the viewer settings from LCD/Finder "Auto" to LCD only.
    23,623
    2555
    Sometimes I use a Hoodman loupe. Works good too
    www.guymancusophotography.com
    23,623
    2555
    I do want to do this procedure at some point. For some odd reason and certainly can be my imagination. This camera R2 seems less sensitive.
    Mar 2010
    91
    Thanks.
    I don't see how covering the 1/3 of the eye sensor works, though. I tried using my thumb to cover the sensor partially in a rough test. If I move my hand in to shield the monitor, it still goes off and the viewfinder comes on.
    Dec 2013
    London
    590
    Quote Originally Posted by NoBob View Post
    Thanks.
    It just seems to make it a little less sensitive and thus you can hold the camera closer to the body. Hey it seems to work for me
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Thanks.
    There are two sensors. The one on the left when blocked (~1/3rd) keeps the LCD on. If you move the tape (not your hand or finger!) to the right sensor, it will keep the EVF on.
    Apr 2014
    Marin County, CA
    593
    Sorry for being dense - two sensors? By chance, do you have a photo of your setup? I'm assuming it's best to remove the eyecup when applying the tape.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,606
    21
    Quote Originally Posted by dandrewk View Post
    Remove the eye cup and take a look at your camera. Use a magnifier if needed.
