k-hawinkler
:loco:It make no sense, K-H? You are keep the A9 because the Lexar is discontinued ?
Seems perfectly fine to me ...Sony 12-24mm f/4, 122º Full-Frame Ultra-Ultrawide (2017-)
http://www.kenrockwell.com/sony/lenses/12-24mm.htm
K.R. makes the point that IBIS works well for the image center.
But it can cause fuzzy corners and edges, although the lens itself is sharp in the corners as well.
He demonstrates that by holding his A9 camera less and more steady when shooting the 12-24/4 lens.
Thanks Bart. Seems fine to me as well.Seems perfectly fine to me ...
Aha! Excellent! You've ordered one already ?I will wait a bit to see what real users have to say about the FE 12-24/4. :grin:
Nope Bart, I have not.Aha! Excellent! You've ordered one already ?
:watch:
Thanks, K-H. But it's a lot of reading - so what's your verdict ?Useful discussions about the Sony FE 12-24mm f/4 G Lens
https://www.lensrentals.com/blog/2017/06/sony-fe-12-24-f4-g-mtf-tests/
http://www.fredmiranda.com/forum/topic/1497119
http://www.fredmiranda.com/forum/topic/1498389
http://www.fredmiranda.com/forum/topic/1498485
Thanks Bart. Do you like these ring flares?Thanks, K-H. But it's a lot of reading - so what's your verdict ?
:watch:
I think I will wait on the 16-35 GM. I don't see a personal need for this lens beyond travel use.
The widest lens I still currently own is the 25 Batis.Thanks Tre. Let's hope the 16-35 GM doesn't have any severe flaws.
I will just sit back and use the UWA and WA lenses I already have.
In particular the WATE 16-18-21/4 on TAP and the Batis 25/2 with AF have served me well. Then there is Choppy my CV 15/4.5 III M-mount, the CV 10/5.6 E-mount, the Nikkor 14-24/2.8, and the older Nikkor 28/1.4 with an hand ground aspherical element.
I just ordered an Opto-Sigma 5M PCX filter and will find out if it does anything positive for my other Leica WA lenses. :grin:
