Results 1 to 17 of 17
Thread: A superfast Tele on the G1
    Senior Member petermcwerner's Avatar
    Jan 2009
    Geneva, Switzerland
    511
    Some time ago I had bought a 75mm/1.3 Kilfitt Zoomar that I had never been able to put to good use before. It comes in a Leica Screw Mount and attaches easily to the G1 via a LSM->m4/3 adapter, focusing from infinity down to approx. 30cm. It covers the whole 4/3 frame with no noticeable vignetting. DOF fully open is of course minimal. Some shots on a walk on a wintry day. Contrast is quite good and the details it can provide are fabulous.
    The beauty and the beast
    Peter Werner
    Leica M8, R9+DMR & Digilux 2; Nikon D700; Panasonic FX01, FX150 & G1; Samsung TL350 (WB 2000)
    JJYL430
    Re: A superfast Tele on the G1
    looks great, seems like a very heavy lens too
    Senior Member bensonga's Avatar
    Alaska
    2,416
    819
    Very nice results!
    I'll have to try my non-AI Nikkor 180mm f2.8 on my G1....not quite "super fast", but reasonably fast for that vintage lens.
    Gothenburg, Sweden
    1,309
    Thank you Peter.
    I always like to see samples from odd, rare or fast lenses like this one.
    noirist
    Very nice! I'd love to have such a fast telephoto lens for my GH1.
    Member slau's Avatar
    Jun 2009
    AB, Canada
    185
    What are the weird color (blue and yellow) on your 5th image (pear, apple?)? Are they CA? What kind of aperture did you use to take that shot?
    Do you find such a heavy lens balance well on the G1? I am hesitate to use heavy lenses that are without lens collar on my G1/GH1, as the camera body is so light and the lens mount may not built to take such stress on regular usage.
    Thanks.
    Stephen Lau
    Calgary, Alberta, Canada
    http://www.pbase.com/stephenl
    Jan 2009
    Geneva, Switzerland
    511
    Quote Originally Posted by slau View Post
    That shot was taken at f/1.3, fully open, hand held, focusing on the rightmost apple. At that aperture, DOF is very shallow and most other objects are OOF. Also, it cannot be excluded that I may have moved slightly between focusing and shutter release. Finally, the scene was backlit, about the most demanding conditions for testing a lens.
    The max. recommended lens weight for the G1 is 1000g (1 kg). This Zoomatar weighs 560g including the built-in sun shade and the mount adapter and it did not feel uncomfortable to handle. There are several threads in the forum with tips on how to best use heavy lenses on the G1.
    Cheers
    Peter
    Peter Werner
    Senior Member kds315's Avatar
    Sep 2009
    Weinheim, Germany
    1,441
    The color effects in image 5 is lateral chromatic aberration (LCA), which is very hard to correct at such high speed lens designs.
    Astonishingly good Peter, I would have expected a sharp, but much less contrasty image (from experience with other fast lesnbes of that maker)
    Jun 2009
    AB, Canada
    185
    Quote Originally Posted by petermcwerner View Post
    Cheers
    Peter
    Thank you, Peter. Where did you find the information regarding the max weight of lens for G1? I was thinking about to try my Canon 85f1.2, which weights over 1Kg. As the lens is so 'front heavy', I am more concern about the torque on the lens mount instead of just weight.
    Stephen Lau
    Gothenburg, Sweden
    1,309
    The 1kg max limit comes from Panasonic. I think you should consider it as a guide line only. A front heavy lens weighting a kg is probably too much in the long run.
    Jan 2008
    North Vancouver, BC
    1,168
    At that point, you simply support the lens instead!
    Jun 2009
    AB, Canada
    185
    Quote Originally Posted by simonclivehughes View Post
    That was why I have been using only lens with lens collar on my G1/GH1. So far, I like the 70-200f2.8IS with my G1 for indoor shooting wide open. Unfortunately a tripod is needed to support the lens/body as the IS does not work with the Panasonic body, and to take the stress off the lens mount. I cannot shoot handheld with the long end of the zoom under indoor ligthing.
    Stephen Lau
    Jun 2009
    AB, Canada
    185
    Quote Originally Posted by Jonas View Post
    Thank you Jonas. I did a search in my user manual and could not find the max wieght guideline/recommendation. Would you happen to have a link handy or point me to the right direction?
    Stephen Lau
    Gothenburg, Sweden
    1,309
    I'm sorry Stephen, I don't have a link. It is somewhere at the Panasonic 4/3 support site. It's like a year ago I read it and the only reason remembering it is that it is such a nice round number.
    Jan 2009
    Geneva, Switzerland
    511
    A good way is with the Manfrotto 293 Telephoto Lens Support
    Cheers
    Peter
    Peter Werner
    Gothenburg, Sweden
    1,309
    +1
    I have the same support since a couple of years. Simple, cheap and working. In theory I admire the Arca and RRS and... stuff, but in real life I have the Manfrotto QR plate shown in Peter's image mounted to the camera all the time, and a Manfrotto ball head to match of course. That way it is super easy to sometimes mount the 293 support to the tripod and then the camera on the top.
    I see you use the velcro strap Peter. I haven't found it particularly useful. Maybe if you carry around the tripod with the whole setup mounted?
    regards,
    Jonas
    Jan 2009
    Geneva, Switzerland
    511
    Jonas,
    It is useful mainly for vertical shots. Without it, the weight of the lens would not be supported. I also use the camera+lens+support hand held and like this I can carry the setup face (lens) down. It makes it is much easier to walk around carrying the assembly with one hand.
    Fountain in Nyon - Kinoptik Tegea 9.8mm/1.8 on Panasonic G1 with Manfrotto 293 - hand held
    Peter
    Peter Werner
