Results 1 to 20 of 20
Thread: IR Conversion DIY or Service
    Jun 2010
    110
    There are a few people here with IR converted cameras. Would you mind posting where you got it done, with pricing and a rating of the shop ? Also, is there anyone with a GF1 who would be willing to post a DIY Howto guide ?
    Perhaps this thread could be an IR conversion FAQ.
    477
    Re: IR Conversion DIY or Service
    I used Precision Camera for my G1. They were a bit over $200. I do not remember the exact amount. I have been quite happy so far with the results.
    Doug
    Jun 2010
    110
    Was that the 715nm conversion ?
    477
    Yes, it was.
    I went with that based on discussions I had with others (particularly Vivek and Jack) here.
    Doug
    Jun 2010
    110
    Has anyone done the 665nm conversion that allows some visible light ? I am looking for a false color effect more than anything else, and it seems (from my limited knowledge) that the 715nm gives less saturation.
    Senior Member kds315's Avatar
    Sep 2009
    Weinheim, Germany
    1,441
    Look for the "Enhanced" or "Super Color" conversion here http://www.lifepixel.com/
    Enhanced:
    Super Color:
    (c) lifepixel.com
    Nov 2009
    Staten Island, NYC, NY
    71
    I used Spencer Camera in Utah. (http://spencerscamera.com/default.aspx) and was very happy with the price and turn-around time.
    I did a 720nm conversion because I primarily wanted traditional B&W IR shots, but still wanted the possibility to work with the "faux color" in RAW.
    I liked the idea of the full spectrum camera - because you can use it for "normal" shooting also, but did not love the idea of having to use different filters on all my lenses for different effects.
    Some sample shots if you are interested.:
    http://www.pbase.com/swandy/gallery/...ed_photography
    Steve
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    A few things to note:
    1. False colors will be not so nice (as the linked "lifepixel" samples) with the Panasonic NMOS sensor (ie any m4/3rds cam).
    2. Make sure you get the cam converted by someone who is capable of doing it in such a way that all lenses would focus to infinity and not just a few feet.
    3. Stopping down a lens to "achieve" infinity is a bad idea with IR on a m4/3rds cam as at around f/5.6 you would start to see image degradation due to diffraction (yes, diffraction sets in earlier in IR).
    Jun 2010
    110
    Vivek, I wanted to convert the GF1 to shoot a film. The setting is in the future, a post apocalypse scenario. Instead of doing color grading, if I can get a different look in camera, its better for me.
    Because there has been war, the composition of the atmosphere has changed, hence the light looks different, yada yada.
    Is there a link to examples for "false color" from NMOS cameras ?
    Aug 2010
    33
    What about using IR filters? I know the m4/3 sensor has IR filtration, but how much IR passes through?
    I've just ordered two affordable (720nm and 960nm) IR filters from China to test, so I'm hopeful but I believe I'll be working with rather prolonged exposures due to the IR filtration of the sensor.
    Any experience with these?
    Aug 2010
    33
    I've just tested my GF1 with a remote control and I can see the IR emitted as a bright magenta, so I think the IR filtration might allow a workable amount of IR through.
    Jun 2010
    110
    Please post examples when you get them up. The remote may not be the best example as its a focussed IR beam - quite strong in the centre. IR light in the atmosphere may not be so focussed.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    False color samples (Sony CCD):
    Nikon D80-IR (Hoya R72), 10.5mm fisheye Nikkor.
    Untitled by Vivek Iyer, on Flickr
    Nikon D80-IR, 18-55 kitzoom.
    Although the color palette is similar with the NMOS sensor output, the colors are less vibrant and if you try (in the post) to make them look like the ones I show, they literally fall apart.
    If you want nice false colors, buy a Sony (CCD) sensored, get it converted. They are very cheap and you get a Pentax, Sony, Nikon, etc brand.
    Jun 2010
    110
    Problem is that the choice for video cameras is much less. I cant get a Sony CCD camera comparable to the GH1 or the GF1. This is still pretty good, and I dont mind if the color saturation is less.
    What conversion did you use for these pics ?
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,601
    21
    Quote Originally Posted by zcream View Post
    Already stated.
    Even with no IR filter (after getting rid of the IR cut filter), you will never be able to get the colors one would from the Sony Bayer dyes. I am not sure if this is extendable to Sony's CMOS sensors (ie, NEX5, etc). If it works then you have a choice there.
    Los Angeles CA
    262
    2
    Vivek,
    All 4 ir photos are very nice especially. I really like the first and last photo you posted.
    Jun 2010
    110
    Vivek I thought you also converted a G1
    Jun 2010
    110
    Thus far, there are 4 options for conversion.
    Precision camera
    MaxMax
    LifePixel
    Spencers Camera
  19. #19
    Administrator Bob's Avatar
    Prescott, Arizona
    4,492
    367
    GF1 IR Precision Camera conversion
    -bob
  20. #20
    seakayaker's Avatar
    Apr 2010
    Seattle, WA
    2,889
    Beautiful Shot Bob!
    Love it!
    Life is Grand!
    Dan
