There is a lengthy thread on DPReview about the Godox XPro F trigger not working with the 100 II. I don't use flash very often so this was all new to me but I do have a Godox and the XPro F trigger and sure enough it does not work properly. When installed into the shoe the EVF will not work - the LCD will and the camera will trigger the flash. If the trigger is moved back in the shoe just slightly the EVF will work ( at least mine does ) but the camera will not trigger the flash. There is lots of finger pointing with some saying pins are not aligning and all saying that Godox needs to update the firmware. I don't know what to think but I my first hunch is that it is not a pin alignment issue. If it were then when the trigger is installed properly ( all the way forward in the shoe ) I would expect the flash not to trigger. But that is not the case. For me the easy work around is just to use a loupe on the LCD for the few times I would use flash. But for others this is a major issue and makes the camera useless - at least when using Godox.
Victor B.
Victor B.
