As the price of 16mm cine lenses are going sky high, I try to explore the alternative world of c mount lens for G1. There are several prime camera producers such as Canon, Fujifilm, Pentax (Cosmicar), etc, made some quality TV lenses. After a series of research, I monitored eBay for about a month to try my luck on some usable items and get 4 lenses so far.
The lens are list below:
1) Canon TV lens 25mm F1.4, most usable, cover 3:2 with little dark corner;
2) Navitron 75mm F1.3, cover whole sensor but unable to focus infinity;
3) Cosmicar 12.5mm F1.4, just barely screw in as the diameter of the rear threat is larger than the adapter;
4) Norita Kogaku 6mm F1.8, cover diameter 17mm, fisheye like, uable to focus
Canon 25mm F1.4 (Right bottom); Navitron 75mm F1.3 (Right top);
Cosmicar 12.5mm F1.4 (Left bottom) ; Norita Kogaku 6mm F1.8 (Right top)
From the info above, just Canon and Navitron are able to use on G1. Other two need some modification to trim the rear mount to fit into the adapter.
Let’s see the result
G1 25mm setting:
G1 25mm setting:
