I’ve got a 70 and 90 digital magenta ring. Had them on buy sell for awhile. No takers.
The problem is that the most people did not understand that the magenta 70 mm and 90 mm have absolutly no difference to the Blue ring 70 mm and 90 mm.
They think that for the change must be a real reason, an update or technical, optical progress, but there is non. absolutly zero.
I talk with the man who develope both lenses- there are no differences. The change of the color of the rings and of the name had only reason in new public relation.
So the new name was introduced: Digaron.
The Digarons get then 3 groups, the IC is there now the reason for the name of the lens.
But the 70 mm and 90 mm are a completely different lenses.
90 mm is a classic symmetrical wide angle lensedesign: Biogon/Grandagon. 8 Elements lensdesign, but compared with film grandagons with smaller IC. You can compare this lens to superior Nikkor 8/90 mm that have bigger image angle of 105°, or the latest Schneider Super Angulon 6,8/90 mm that has also 8 element lensdesign and smaller 100° image angle, that make him sharper.
The 70 mm is indeed a modern retrofocus lens and the father of all digaron-W lenses.
rodenstock made the new retrofocus apo sironar digital HR lenses indeed for smaller sensors, but the 70 mm was made for large scanning backs. also the classic apo sironar digital lenses should at this time be for scanning backs, that had big sensors. It was not clear in what direction the high end photography will go, small high pixels sensors or big scanning backs. the first is now the standart but it could be indeed the different direction the future.
The 70 mm has a much more easy lens design compared to 32-40-50 digaron -W or the new 90 mm digaron-SW. So at the edges you will see a difference. But the developer of the 70 mm was very proud of this lens, it is still pretty good and much cheaper, becouse of the easier lensdesign. Itis still a very good lens and easy to use.
when you need a superb lens for stichings the 90 SW is simply the best option here but if the movements are not crazy large the 70 mm will do the job.
