Greg,
The FSQ106EDX is a great telescope, I have one! Native it covers 88mm image circle and with the reducer its 44mm. The "best" results will come from Monochrome (either narrowband or broadband depending on how dark a site you can get to for broadband). I use the ZWO ASI6200mm (full-frame mono) with the FSQ106, I've also used my Hasselblad X1Dii.
The filter dilemma gets a bit more complex at fast focal ratios, F3.5 is on the borderline, you need a different filter bandpass for fast focal ratios, regular filters probably will work at F3.5, however some folks say the cutoff is F4 before you need to change to the "fast filters" - this is for Narrowband, the broadband don't really matter. And of course if you go full-frame you need minimum 50.4mm unmounted filters (mounted 2" will vignette) and some folks go all the way to 50mm square, although ZWO doesn't make a 50mm square filter holder yet, I use the ZWO 7 position with 50.4mm unmounted round filters. The 645RD reducer is a beast so unless you really need medium format I'd stick with one of the other two versions. I had use of a FLI16800 medium format camera, it was huge, heavy and expensive - and the results weren't noticeably better (plus the pixel size is not really ideal for the FSQ106 - that scope wants small pixels).
The issue with Monochrome is more work in post processing, however its not that bad, compared to the hurdle to get in at all
. OSC is a fast way to start, however I wouldn't spend money on a full-frame OSC, you'll likely never be able to sell it, whereas a Micro4/3 or APS-C OSC has resale value and uses smaller filters.
So an ASI294 (color) is a good choice to start, if you get bitten by the bug they hold their value if you buy used you can probably get most of what you paid back when you upgrade to Mono.
Mount wise my 2 cents: Mach1 or MX/MyT - I now have the Mach2 but had a Mach1 for years. I am a bigger fan of Astro-Physics mounts versus Software Bisque (only because I don't like using The Sky X, although it can be a great all-in-one software package if you get all the different modules - so its very personal just like LR vs C1, etc.). My 5 cents = Mach1 from your list
I wouldn't recommend the iOptron path, they make nice mounts, however there seems to be an issue (QA or not sure what) that many local folks (NM) have had a lot of trouble getting one to fully function. The Skywatcher is like "old reliable" and the CGX-L is fine, however for the money I'd go Mach1 (and get on the list for Mach2 or 1100, no up front commitment and you can decide when your name comes up). You can also get an Astro-Physics AP900 used, and that is a fantastic capable mount, often the AP900 can be had for less than the Mach1). The AP900 breaks down into two very manageable pieces.
Hope this helps?
