Can’t remove back on Linhof
Gizonite
Hello, I recently acquired a Linhof super technica 2 x 3. I have spent hours trying to figure out how to remove the back to change film holders. I can’t believe something can be so complicated. If anybody has an answer to this, please be very specific in explaining how it is done. I would greatly appreciate it so I can get on Using this camera. Thank you so much.
darr
If you need help and not finding it, go to the Large Format Forum, where there are photographers using similar cameras:
abruzzi
It should be a simple 90 degree turn of the release lever in the corner. Link to a video, by Linhof Studio, UK, of the Linhof Super technika 69 (2x3 if American) is below.
Linhof Super technika 69 Overview
That will work on later models (v4 and later I believe.) If you have an earlier model, you start by rotating the back 45 degrees. That will expose a sliding plate on all four exposed corners. Slide each plate away from the center, and the back should come off easily. Later models replaced it with the lever Duff mentions.
