carbon fiber travel tripod-never used $250
theis
$250 (I pay PayPal) + shipping
The Sirui T-2204SK T-S Travel Tripod is a 4-section support with carbon fiber legs. Each section has a twist-lock leg system, which unlocks to enable the legs to extend, along with the 2-stage rapid center column, to reach a maximum height of 56.2". With three variable legs angles and independent leg spread and the use of the included short center column, the legs can completely splay out to have a minimum height of 5.5", which is ideal for macro or low-angle photography.
The magnesium-alloy spider has an integrated bubble level to level out your horizon, and the legs fold in reverse to a compact 15.7". The 3.5 lb travel tripod can support cameras up to 33 lb, and one of the legs is detachable from the tripod and converts into a monopod that can reach a total height of 57.5". Additionally, each rubber foot is removable and can accept a spike foot, which helps to secure the tripod into softer terrain. NO HEAD INCLUDED (but I could throw in a cheap no-name one if you wanted it).
Load Capacity 33 lb / 14.97 kg
Maximum Working Height 56.2" / 142.7 cm
Max Height without Center Column 42" / 106.68 cm
Minimum Working Height 5.5" / 14 cm
Closed Length 15.7" / 39.9 cm
Materials Carbon Fiber, Magnesium Alloy
Legs
Leg Lock Type Twist Lock
Leg Positions 3 Positions
Independent Leg Spread Yes
Leg Sections 4
Leg Diameter 1.2" / 29.4 mm
Bubble Level
Yes
Feet Features
Rubber, Spiked
Detachable Monopod
57.5" / 146.05 cm
Leg Sections 4
Monopod Foot Features Rubber, Spiked
Center Column
Center Column Features Reversible
Center Column Shape Round
Center Column Sections 2
Center Column Extension Type Rapid
Lateral / 90-Degree Center Column No
Center Column Rotation 360°
