The process that Rod (
@4x5Australian) and I used on his->my SK60 XL was as
@rdeloe described - iteratively loosening one of the cells (in this case, the front cell as it's more easily accessible), finding the sweet spot, and then calculating the thickness needed based on the thread pitch - 1/4 turn seemed to be optimal, which IIRC works out to 0.12~0.15mm, although I may have slipped a decimal in there somewhere (h/t to
@dchew for the [correct] info - I don't have the Copal manual with design specs in front of me).
Finding shims of the appropriate thickness (or any thickness, for that matter) proved to be the biggest challenge in my limited experience, however. I contacted multiple shops on multiple continents, some of which after valiantly searching didn't have any, while others just flatly stated "send the lens back to Schneider, you should leave this to the professionals so they can do it right with their test equipment." To which I say maybe - my main use case is shifting out to the edge of the image circle at distant focus, which I don't know falls within the parameters used by the manufacturers (my ultimate test is in the field). And all these DIY shenanigans assume that the lens isn't decentered or otherwise knocked out of spec.
Anyway, looking into this a bit further, one can get a precision metal shop to cut shims for you but this typically requires a minimum order of 100s with a total cost in the neighborhood of $1000+ USD. Any takers?
My solution was one of serendipity: Rod had seen an SK 135 in Copal mount for sale on eBay for not a lot of $$ and a generous return policy, and for some reason the seller had a picture of it broken down into front and rear lens cells and Copal, showing two shims hanging off one of the cells.
@dchew (Dave) was looking for a spare Copal shutter so on a gamble I purchased the lens. When it arrived, one of the shims was missing but as luck would have it, the remaining shim gave a 1/4 turn offset, so I installed it on my lens and shipped the rest to Dave.
Final note(s): while I optimized the lens to offset field curvature, this wound up introducing longitudinal chromatic aberration (purple fringing) at the edge of the image circle. A thinner shim may have been a better compromise but I found that Capture One's purple defringing tool could mostly eliminate the fringing. It's also important to confirm that you can still hit infinity focus after making the adjustment. If I learned nothing else, "fun" with tech cams can be quite the adventure but worth the effort if one is patient and gets a little help from one's friends.
John
