Epson7890 old ink questions
gurtch
Hello folks. I am an 86 year Amateur that used to sell my framed seascape prints to feed the habit. I have not used my 7890 in quite a while as the Pandemic really screwed up my little side business (we live in a summer resort area). I have to make a big 24"x32" matted and framed print as a donation to our local Maritime Museum Fund Raiser. When I fired up the printer and tried to print out a test print nozzle check, it came out blank (not good news). The printer showed a warning that one ink was empty. I checked and I had a spare 150ml cartridge. I had mistakenly cut open the sealed plastic wrap, some months ago, then realized my error, and taped the bag shut. When I put this in my printer I got an "X" warning that said "cartridge error" . I assume this must mean the ink in the opened cartridge partially dried up. I did remove and shake it, and replace several times. I tried to run a nozzle clean again several times, and still get low ink warnings on three other colors, plus the "X" bad cartridge warning. I ordered a brand new cartridge for that color (LLK), and ordered the three other colors from ebay that are factory sealed and boxed but out of date at a low price. My thought process is I will waste a lot of ink running multiple nozzle cleaning sessions, so why waste new ink? Once everything is up and running I will probably get brand new inks. Every time in the past that I have had to run multiple nozzle cleanings I make a resolution to print a nozzle check pattern weekly, but I never do. To make matters worse we live on a barrier island, bay front, and we have a lot of damp salt air conditions. I guess I am looking for advice (other than scolding me for letting it go so long between nozzle checks). Thanks and be kind to an old man. TIA.
Dave Gurtcheff
Beach Haven, NJ
web site to see what I do:
www.modernpictorials.com
I have had the same problem with my 7800. I followed this description.
Didn't have any cleaning fluid but apparently Windex works fine I've heard. We don't have Windex here in Sweden but I guess it's window cleaner. The important thing is that it contains Ammonia. I guess it's better to buy real cleaning fluid but sometimes you're in a hurry.
I let it stand for 24 hours and changed the paper sheets a few times and then I had to do a number of nozzle cleanings.
MartinN
My consensus has been with Epson, I do an automatic cleaning, then wait at least a few hours before printing a nozzle check, then doing another cycle if needed. For stubborn things I would probably do one cleaning and then wait until the next day to see if it has improved. I have not had to do any take aparts (yet), but of course drying up for months or years can be a different thing.
MartinN
BTW, I can’t believe the cartridges are smart, they can’t know anything more than the ’estimated ink use’ so an cartridge error would indicate some dirt on the ’dumb chip contacts surface’ or something similar.
gurtch
Thanks guys. I did use a little packaged alcohol swab and wiped down the little chip. That did not help, but I am going to try again today before I throw away a new, full cartridge. Also as suggested above I am going to try a nozzle pattern print after having waited a day. Again thanks.
Dave
gurtch
Somewhat of a miracle: Last night I recleaned the chip and reinstalled the cartridge that gave me the error warning. The printer then said cleaning, please wait. I waited for 4 or 5 hours and nothing happened. The printer made no "cleaning noises". Before bed time I decided to power off the printer. It hung up and said shutting down please wait, but nothing happened, it would not power off. I waited and it would not power off, so I went to bed, thinking I would need to craw behind the printer and pull the power plug to shut it off. When I got up this morning the printer had powered off! I fired it up, did one nozzle cleaning and made a nozzle check print, and it was perfect! I made a successful 20"x30" print. When the print was finished I got a clogged nozzle warning so I did a cleaning cycle. That finished and I got another clogged warning and asked if I wanted to repeat the cleaning, which I did, and the warnings all went away, I shut down the printer, and covered it up. My wife marked up our calendar we keep on the refrigerator with "Nozzle Check" on every Saturday for the remainder of the year. I mounted, matted and framed the image and we are donating it to the local Maritime Museum Fund raiser. It is a scene never to be seen again, as the quaint buildings (shacks) in the background were knocked down and replaced with multi level condos. I think the print will auction off at a nice amount for the museum. Here is the image;
MartinN
Yes, a few prints or maybe nozzle check every month is minmun, I think, but nice to hear that long storage may be recovered.
gurtch
Yes, Martin, happy ending. I also have an Epson P800 for my smaller prints. It has never clogged, but I use it more often. I decided when I run a nozzle check on the big printer, I might as well do it with the P800. I figure it can't hurt, and with my advancing age I do not print as often as I used to.
Dave
