Guess that given the absence of a floating element for close-range correction, the 80, 100, 120 are very purpose built rather than flexible tools. The benefit of razor-sharp infinity images would have been nice on the 100. I passed up on a 100/3.5 CF because of the thread; unfortunately, it hasn't left me with that much clarity.
Indeed, it's difficult to gain clarity when we each have different standards for what's acceptable image quality, not to mention different use cases. For example, what are we referring to when we say "close- to mid-distance," what size and type sensor are we using, etc., etc. In any case, I thought I'd do a quick and dirty test of my 3.5/100 CF (emphasis on *quick*) compared to my 5.6/120 S-Planar, the latter I believe to be a superb lens at close distances (here defined as magnifications of 1:5 or greater - I use this lens quite happily for all of my macro images).
The test: books on my bookshelf (pardon the dust)
Camera/sensor: Cambo WRS1250/IQ4 150, shifted 5mm vertically to include the shelf the books are sitting on
Exposure: 3s
Aperture: f/8
Focus distances: approx. 1m
Width of subject in frame: approx. 38 cm (I did my best to match this for the two lenses) - compare to sensor width of 54mm
Processing: (my) default settings in C1 v21; links to full sized jpegs below.
Caveats: there are many, not the least of which was my ability to focus and line up the sensor parallel to the bookshelf itself (I did my best by leveling the camera and then rotating it to bring the shelf parallel to the bottom of the frame).
My conclusions:
• The 3.5/100 CF Planar acquits itself pretty well. It's a bit less sharp overall compared to the 5.6/120 S-Planar, more noticeably so at the edges. How much of this is due to lens performance vs. my sloppiness with focus and alignment, I can't say. And how much this might matter, well, just depends on what you're looking to achieve. Note that these are humongous 150 Mp files that would print at 47" wide @ 300 ppi and would sharpen up nicely e.g. with Topaz Sharpen.
• With the 3.5/100 CF there's also a bit of chromatic aberration that cleans up nicely in C1 (what you're seeing is an uncorrected image), so I would consider this mostly a non-issue.
• I'm guessing that stopping down to f/11 would narrow the differences between these two lenses. Don't ask me why I didn't try this but the kit is stowed so we'll just need to speculate on this point.
• YMMV...
Here are the images. Click on the links and pixel-peep to your heart's content.
First, the 3.5/100 CF Planar:
Lens test: Zeiss 3.5/100 CF Planar by
John Ngai, on Flickr
And the 5.6/120 S-Planar:
Lens test: Zeiss 5.6/120 S-Planar by
Hope this helps!
John
