Paul Spinnler
The FPS is great, but it was conceived in the era before mirrorless and the key mount to include nowadays (FFD being the problem so far with 3rd party cameras) would be the GFX one. There are so many adapters out there for Fuji so if you build a bridge to Fuji you open the door to many other things. The FPS construction might not allow for GFX, but I am not sure.I think I was unclear, there exists for example Contax 645 to GFX AF adapters and Canon EF to GFX adapters that can autofocus.
Separately, I did reverse engineer the Mamiya/Phase lens protocol, which is just an extension of the same SPI bus used to interface Phase backs. I never did anything with the project though, and autofocus would be a hole thing since they are screw drives lenses. I can do the CSE/EE, just the mechanical engineering is a bit beyond me for something like that.
Alpa with their FPS has a pretty similar setup to the Pico it seems, though I prefer the alpa setup with their swappable lens modules. (Also, why did they stop making the Rollei 6000 adapter? Was it because DW photo is the worst to deal with? )
For example, I saw that there are I think 0.8x reduction adapters which increase speed from Pentax 6x7 to GFX – imagine how cool that is to use the 105 Takumar 2.4 focal reduced on an IQ4.
So if the FFD is 26.7 for Fuji it mens there is only 4.5mm to integrate the GFX mount, probably not enough for a smart adapter and not easy for a dumb adapter either.
That would literally be a dream if they made an aperture control adapter which can accept Fuji G.
The big benefit of the bellows type design is that a) you can mount camera bodies with handgrips while still being able to do X/Y shifting and b) you can get closer FFD wise as you work with two carriers on a rail instead of a body frame in-between.
That's the key to the mirrorless world and if they build it in a smart way one could even adapte Nikon Z – I am talking about the Nikkor 58 0.95 ... which is sharp wide open!
This said, the Pico with its own shutter and carrier / bellows system will be a dream tool to adapt any lens onto anything. A real tool for 2024 and beyond ... its basically FPS reloaded in a typical Arca kind of way – engineering-wise built in the smartest way, but as a classic bellows cam. Reminds me of the genius in the R system which mounted the helical into the body, thereby lowering lens costs for everyone by making tilt a body feature and by moving the helical out of the lens onto the body as well.
Here they take it one step further – everything except the optics is moved onto the body which means any lens can be adapted if you dont have an in-between body frame. You don't even need a tube for copal lenses as you have rails and move standards apart as much as you like ... genius.
