Many thanks Barry. What a stunning image! WOW!Foggintor Quarry Dartmoor...A7RII + 21mm Loxia
The stone that was quarried from here went into the construction of the historic Princetown prison on Dartmoor (1806)
History of Dartmoor Prison
Many thanks Karl, most appreciated.Many thanks Barry. What a stunning image! WOW!
I love the composition, light, colors, texture, mood, and the waves in the water that give it a rather graphical component as well.
Perfect post-processing masterfully done!
The image has your signature features, easily recognizable without reading the label.
Thanks Barry. No, I haven't.Many thanks Karl, most appreciated.
Slight change of subject...Did you finally manage to get yourself a "E" mount CV15 in the end...I know that you have Guy's "Choppie" + acquired a very nice CV10 "E" mount?
TIA, Cheers Barry
Thanks again Karl bringing me up to date with the situation, most appreciated......Not sure then if I can even be bothered taking another chance on getting yet another 15mm again, that's if Voigtlander can't address a problem experienced by many of us...Might now try the CV12mm "E" mount or the 12mm Laowa, depending upon which one comes out on top...Cheers BarryThanks Barry. No, I haven't.
The 15/4.5 E-mount became just available again but has the same copy variation problem. Voigtländer doesn't admit they have a problem, according to this email from them. Voigtlander 15/4.5 III E-mount Rolling review - FM Forums
So, getting a good one will continue to be a crap shoot. No thanks at this time.
I am using Choppy on my TechArt Pro autofocus adapter that also enters the focal length into the Exif. I can live with that and have AF and 5-axis IBIS image stabilization. Techart PRO AF adapter now In Stock at B&H Photo - FM Forums
I really like as well my E-Mount 10/5.6. Here AF is not important, simply set focus to infinity, aperture to f/9, and shoot to get a sharp image pretty much almost into the corners. F/8 or f/9 seems to be the sweet spot, slightly improving the corners over f/5.6. I am using f/9 or f/11 a lot for increased DoF.
Thanks Barry.Thanks again Karl bringing me up to date with the situation, most appreciated......Not sure then if I can even be bothered taking another chance on getting yet another 15mm again, that's if Voigtlander can't address a problem experienced by many of us...Might now try the CV12mm "E" mount or the 12mm Laowa, depending upon which one comes out on top...Cheers Barry
Thanks for that Karl that's all very helpful, will do ...the 10mm does indeed seem less troublesome as you say (glad you got yourself a good'un)...It's amazing that they can get the 10mm so right, yet they can still screw up some of the 15mm lenses now in it's 3rd generation!!!...I have had a sum total of 4 number 15mm lenses from Voigtlander since the Mk1 and not one of them was particularly good in the corners...enough is enough for me.Thanks Barry.
You may want to have a look at the 10/5.6 as well. So far only very few copy variation issues have surfaced.
http://www.fredmiranda.com/forum/topic/1429742/0#13555559
http://www.fredmiranda.com/forum/topic/1445433/0#13680289
The bulk of the 10/5.6 lenses delivered, including mine, are sharp in the center and across the lens except for the extreme corners at f/5.6. No smearing though, as happens for many of the 15/4.5 III VM- or E-mounts, including the one I sent back. Of course, a good copy of the 15/4.5 III, such as Choppy, has sharp corners even wide open that minimally improve by f/5.6.
A Voigtländer 10/5.6 lens is different in this sense, only the very extreme corners never get completely sharp.
But for my taste they are sharp enough and have no smearing.
Please have a look at my 10/5.6 lens, full resolution, f/5.6-f/22.
https://winklers.smugmug.com/KHW/Pics-by-Date/2016-06-07-A7r21056-FE-Corner/i-LrHfSJ3
My lens seems typical for most of these lenses delivered.
Barry, please let us know about your take on the CV12mm "E" mount or the 12mm Laowa. TIA
Cheers, Karl-Heinz
